CalvinT
Calvin
Phoenix, AZ
If you want a more permanent finish, Plastidip has a primer that improves adhesion. But if you use their primer you won't be able to peel off the Plastidip later.
VAtruck
Yeah, the Bronco looks better with a darker or black roll bar as opposed to the body color - unless you got a black Bronc.
Yup. Every time I see a Bronco with the hard top off, my impression is of a partially assembled vehicle on an assembly line, rather than a role bar.
Mean Green
Warminster, PA
23 Ford Bronco 2dr Badlands Sasquatch
One of my favorite builds just keeps getting better! Keep up the great work.
KRAKEN
KRAKEN
Andy
North Alabama
2023 2 DOOR BRONCO, 2014 F150 XLT, 2006 F150 FX4
What back window molle panels are those? I'm looking for something that still allows for easy hard top removal and it seems like those have the screws on the inside if I'm seeing correctly?
They are TESIN brand from ebay. You have to remove them to get the top off. The bolts are on the inside of the bottom, but the back of the panel sits outside the roll bar so you can't just undo the bottom bolts and pull the panel in to clear the roof lip at the bottom. I put thumb screws in the top of the panels which along with the Rorkworkz bottom bolts make removal/installation tool free. Oh, and the driver's side needed modification to run the rear wiper hose through.
Ford Bronco Plasti Dipped my Roll Bar 20240426_095534
Ford Bronco Plasti Dipped my Roll Bar 20240214_112748
Ford Bronco Plasti Dipped my Roll Bar 20240218_110211
Ford Bronco Plasti Dipped my Roll Bar 20240218_152922
