Panda Motorworks BPV Delete Kit for 2.7L!
Mitch Panda Motorworks
Mitch
St. Louis, MO
www.pandamotorworks.com
2021 Ford Bronco, 2014 Fiesta ST
Since we've released our BPV delete kit for 2.3L we've been getting tons of questions on whether or not it will work for the 2.7L, and we confirmed that it DOES in fact fit! This product isn't for everyone but if you are looking for some more blow-off noise this is a cheap, effective way of doing so!
If you're curious about what our BPV Delete is or want to learn more, check out the video below!
If you are looking to pick up a kit, click this link--->https://www.pandamotorworks.com/pro...-ford-bronco-2-7l?_pos=1&_sid=54e241750&_ss=r
UNBROKN
Central Virginia
04 F-350 CC dually, 97 Infiniti QX4, 21 Bronco BD
Too much music in the background. Could not hear anything. How about a before and after sound bite?
Mitch
St. Louis, MO
Here is a sound clip of the raw audio. Keep in mind this is the 2.3L, but you'll get a similar effect on the 2.7L
SPITmadFIRE
CA
Ahh yes — venting to atmosphere on an engine that really benefits from not wasting all that boost it built up.
While blow off sounds cool, it’s important to note that this will negatively affect your mileage, performance, and warranty. Installing blow off valves on Focus RS 2.3L’s was common, but the real mod folks were doing to their BPVs was replacing them with beefier aluminum ones from mountune to prevent failure at higher boost.
chris@pandamotorworks
St. Louis
2016 F250, 2013 Ford Focus ST
This will not hurt mileage performance, or void a warranty. Its a stock part just took the hose off. If you are that worried then put it back on before going in.
ex_nyer
Chokes
Connecticut
F150, Land Cruiser, Outback
I love that animal/insect hanging on for the ride! lol
SPITmadFIRE
CA
To be clear, I'm not "worried" about mileage, performance, or warranty voiding. My Focus RS has plenty of modifications done to it that could affect all of those.
Do you have any sort of metrics that show venting to atmosphere, and completely disabling the recirculation of that excess boost pressure does not harm mileage or performance? In BPV/recirc applications like this, venting to atmosphere means the engine has to re-build all of that boost when you level off the throttle to shift, or maintain a given speed. The BPV/recirc system is a huge component of the anti-lag system, at least for other 2.3L ecoboost applications.
St. Louis
The car does not have a anti lag system on it if we are talking about a Focus RS. The only thing that keeps the RS from not loosing boost is with a tune and Flat Foot Shifting. Regardless of BPV or BOV the car will still loose boost unless tuned. These cars being MAP based vs MAF based means this will have no negative effect on your fueling or boost curve aka not loosing any performance or millage.
The truth is factory uses a BPV for EPA & answering the consumers questions on why their car makes a weird noise.
Ig_bronco
Matthew
Pittsburgh PA
2014 JKU
Listen... I'm kinda retarded... Lag? My 2.7 has a bov.. When I let off the gas and it hisses at me then push again there is a lul in response. That what you mean? And I thought a bov was good so all that hot unused air isn't reused.
St. Louis
Upgrading to a full replacement has its benefits and extra protection! If you just want a little more sound this $5 mod is perfect!
05TreeFiddy
Jake
Ma
05 F350
Where on the 2.7 does this go?
