- Mitch
- Apr 7, 2021
- 91
- 291
- 998
- St. Louis, MO
- Website
- www.pandamotorworks.com
- 2021 Ford Bronco, 2014 Fiesta ST
- Outer Banks
Improve the power and performance on your 2021+ Ford Bronco with the Stainless Works Downpipe. This system comes with 3" stainless steel tubing and a slip fit G-Sport catalytic converter OBD2 or G-Sport UHO GEN2 Advanced. With two connection options to choose from, a factory connect to connect to the factory catback or performance connect to connect with the Stainless works cutback this is a true 3" system with no neck downs or restrictions!
This system is built from corrosion resistant 304 stainless steel and TIG welded at Stainless Works state of the art facility in Streetsboro, Ohio. This product is backed by a lifetime warranty on materials and craftsmanship.
As mentioned above, the downpipe comes with 2 catalytic converter options with a gap in pricing between the two. I will explain the difference between the tow which will explain the cost difference.
G-Sport Catalytic Converter OBD2:
G-Sport UHO GEN2 Advanced:
Quick Facts:
- High flow cats
- May not be optimized for use with advanced oxygen sensor systems, potentially causing issues with fuel efficiency and will trigger check engine light.
- 300 CPSI
- Horsepower Rating: N/A
- High flow cats (EPA Compliant)
- Designed to work seamlessly with modern oxygen sensor systems, optimizing fuel combustion and minimizing emissions. In most setups, won’t trigger check engine light (Not Guaranteed)
- 400 Cells per square inch S-Wound
- Horsepower Rating: 350-500 per bank
Quick Facts:
- 3" mandrel bent 304 stainless steel
- Choice Between Factory Connect or Performance Connect (both included)
- Bolt-on installation, no welding required
- American Made
- Tig Welded for Strength and Beauty
