SpikeBronco
JB
Houston
Bronco 4Dr
Installed the downpipes today. I had them Jet-hot coated as I was concerned with the lack of heat shields compared to factory.
I'm running an AFE dual muffler exhaust with single outlet. Still pretty tame after the downpipes installed and no rasp. I had originally went with a dual muffler and single outlet exhaust as I didn't want the exhaust to be much louder than stock, just more throaty.
I just got the whole turbo-back system in, and I have not installed it yet because I am looking into getting a coating like this done locally both for heat, and because I want the muffler black so it isnt so visible underneath. Does anyone have any feedback on getting this type of coating done and the performance? Any suggestions for a good place in the Houston area?
Gluestick
Josh
Nashville
instagram.com
BMW X5, Bronco Badsquatch
I have done it before on motorcycle headers and it’s awesome.
cosmicsloth
Rob
2023 Big Bend, 1956 Chevy Bel-Air
Its the corsa pro series resonator 2.5" (stock piping). One thing to note is its not bolt on ready if youre thinking of doing it yourself. The resonator needs to be expanded on both ends for the "slip fits" so the stock midpipe can slide in.
Installed my set of CVF downpipes today and have the same rasp as everyone else has mentioned. I already ordered the Corsa resonator. Quick question regarding your statement about expanding the ends, is this something I can do at the house or do I need to take it somewhere to have it done?
21BRONCO
William
Los Angeles
you can take it to a muffler shop and have them expand it. or purchase a expander on harbor freight to save some money. But be warned its a pain without a way to clamp down the resonator to keep it from spinning.
cosmicsloth
Rob
Thanks for the feedback, didn't think it would need to be expanded that much being the resonator is supposed to be 2.5" slip fits, but I'll snag an expander. Do you mind sharing a picture of the resonator installed?
I'm basically going to be having the same setup, CVF downpipes, this resonator, and the Magnaflow Street setup.
21BRONCO
William
Los Angeles
Corsa lists it as "Slip-on" but they never expanded it. They only cut the slots in. Seems like they're getting lazy. I'll snap a photo over the weekend. I took the stock exhaust off and installed a corsa and man... the rattles back even after a resonator. Debating if I should install another corsa's smallest resonator that's for the 2.7" piping (because that's all I have the space for now).
cosmicsloth
Rob
Damn, that's unfortunate to hear. I'm mainly trying to just get some of the rasp at 3800-4000 down a bit. Not sure what it is about these motors, but there is just no way to get them to sound good. Then again, I've been saying that about all Ford motors since they came out with the Coyote.
21BRONCO
William
Los Angeles
Yup, thats the rpms i was getting my rasp with the stock exhaust. If you have the stock exhaust then the corsa resonator will get rid of the rasp.
cosmicsloth
Rob
I've got the Magnaflow Street Series Axleback which is one of the more tame aftermarket ones out there. It sounds great with stock downpipes, but once throwing these on its a bit over the top. Granted everything before 3500 and after 4200 sounds absolutely great, super deep tone. Just that mid range that needs to be figured out. So hoping the resonator does the job.
cosmicsloth
Rob
Quick update, got the Corsa resonator installed today and it definitely takes away a ton of the rasp. So regarding the downpipes, I definitely recommend spending a few extra dollars to add in a resonator in the midpipe or you're going to have a bunch of annoying rasp at 3800-4200. I also recommend getting at least a 14" resonator instead of a little stubby one, my Bronco sounds nice and deep again, which is hard to do with these 2.7 Ecoboost motors.
But the downpipes themselves are a work of art. CVF has killer products for the Broncos and you can't beat the price for some high-quality products.
