P/N L1MZ-6A949-C Ford Ranger Lariat 2.3L I4 Engine Cover Fits the Bronco 2.3
sts90
Theo
Louisiana
Bronco Heritage
@GoHack I installed one of these on my 2020 Ranger to dampen the engine noise and it worked well. My new Bronco has a sound-deadening hood insert. I am thinking about adding it again for looks and additional noise dampening. Did you notice any change in the cabin after you installed it?
GoHack
GoHack
Palmdale, CA
'23 Bronco
I too have the sound-deadening hood insert as well.
As for the engine cover, it was installed after the sound-deadening hood insert was added, which already cut the sound down. but as for the engine cover doing any, I can't say that I notice any. That wasn't why I ever considered putting it on. It was to simply clean up the looks of the engine, and all the hoses everywhere, which I think it does.
mspeter
MP
NorCal
‘22 Badlands 7-spd, ‘20 F350 Dually, & 3x M422A1s
I installed one of these covers plus the hood ‘blanket’. Used metric wing nuts from McMaster for quick removal. Might have reduced sound a bit.
Another mention on the Ranger Forums hint that the cover will help minimize water that migrates down to the spark plug threads, which cause bad corrosion & removal problems.
BigBendBW
Columbus, Ohio
Bronco Base Sasquatch
Yep. Bastards cost me over $2500 in damage to my F350 from their nest under the turbo catching on fire.
Every vehicle now gets electronic rodent deterrents installed right away.
What deterrents are you using?
HighVelocity
Big Sky Country
Triumph Scrambler, Ferrari 458
