Oracle Occulus headlight issue
Lana2x1206
LAROLYN
Fredericksburg VA
2024 Bronco OBX
I replaced the signature headlights on my 24 OBX with the Oracle Occulus leds. I'm having an issue with the turn and corner lights staying on for 15 minutes or more after turning off the vehicle. I had to update Forscan when I replaced my taillights to get them to work properly. Oracle said to change the light delay setting to 0 on my Sync screen but that hasn't helped. Does anyone know if there is a Forscan setting to change & fix this? Thanks!
OracleLights
New Orleans, LA
www.oraclelights.com
We’re happy to dive back into troubleshooting with you! If you don’t mind, shoot us a DM here or reach back out to our support team directly via email so we can take a closer look and make sure we’re pointing you in the right direction! You can also fill out our online tech support request here: https://www.oraclelights.com/pages/tech-support-form and someone from our technical department will be in contact with you shortly.
jsoa
Jose
Delaware
2024 Bronco 4dr
I've noticed the same issue, it does turn off after a while
When i walk away and look back and they are still on, I usually unlock the truck, wait 5 seconds, then lock it again, and it seems to help them turn off.
tgvbronco
TV
TX
I installed Oracle Bi-led lights on a 2025 Big bend, I bought them because it said plug in play, the headlights and orange halo work. I don't know why the turn signal and side reflectors don't turn on, I guess I need to call Oracle tomorrow, just wondering if it's a Forscan problem, I don't know how to use Forscan, and I don't think the place I bought them will take them back hope there's a fix if anyone here knows I would appreciate some guidance thank you.
Ford Bronco Oracle Occulus headlight issue IMG_20260425_211304729_HDR~3
jsoa
Jose
Delaware
2024 Bronco 4dr
I know the side markers have their own plug that needs to be connected since they are attached the the grille it self, not sure if the ones you circled have a plug as well. Perhaps worth checking those connections.
tgvbronco
TV
TX
Yes everything is plugged, blinkers and side markers just wanted to see if anyone has ran into this problem when I put the blinker to turn the halo turns off so I'm stuck love the look and the light output but need a front blinker don't know if it's a computer problem but I thought they were plug in play.
OracleLights
New Orleans, LA
Sorry you’re running into that, definitely not the experience we want for you! If you’re open to it, our tech team can help walk through it with you and get everything working as intended. You can fill out our tech support form here and someone will follow up directly:
Or feel free to reach out:
[email protected]
1 (800) 407-5776
We’ll get this sorted out for you!
tgvbronco
TV
TX
I fixed it, I wired it wrong......thanks to Oracle for guiding me, I called y'all and the guidance you all gave me, I got them to work
Ford Bronco Oracle Occulus headlight issue file_00000000628871fd871b2b6f184e391f
