Oracle Flush Mount Taillights installed pics
Aloha Sunrise
Hawaii
2021 Toyota Tacoma TRD off road,1971 VW shorty bus
Really like the flush taillights so much I just ordered a set.
69-300
Leon
New jersey
21 Bronco Black Diamond
Any issues installing them - Or was it straightforward ?
Beach_Bum
St. Augustine, FL
2023 Outerbanks Bronco
It is straightforward. But do yourself a favor and get the rubber bump stops that @broncorik shared in the main Flush Mount Taillight thread. You will need 2 for the driver's side. On the OEM taillight you will see Ford used a foam washer/spacer. Oracle provides a collapsible rubber tubing that is frankly garbage. Save yourself the aggravation and get 2 packs of the universal rubber bump stops.
Ford Bronco Oracle Flush Mount Taillights installed pics FlushMount (3)
The big one pictured is what you will use. You will drill a hole with 11/32 drill bit. Then take an exacto blade to clean up the hole as rubber doesn't drill cleanly. On the back side, you will note an inside lip. Cut that way. That recessed back opening fits perfectly over the bolt hole and provides a firm but exact spacing needed to gain the flush mount.
Beach_Bum
St. Augustine, FL
Thank you very much - very clear explanation !
Welcome. You can reference @broncorik original post with more photos and description.
Keep in mind that others have used other items ranging form gluing washers together to reusing left over rubber pieces from the wall-mount t.v.
I used the rubber bump stops on mine.
22MavXLT
Jimmy
East Bend NC
22 Mustang GT, 22 Maverick XLT
Been eyeing these for the Wife. She really wants them, but we need to find a forscan tool so we can flash the computer for them.
rtazz17
Connecticut
2022 Ford bronco big bend
I guess like anything it takes getting used too. I think I like them,lol
‘21OBX
90Bronco19
2022 bronco outer banks
I like them too.
Ford Bronco Oracle Flush Mount Taillights installed pics 6E10885F-F0F9-466C-8C37-548FAF4017DE
Batson35
Ohio
Black Diamond 4Dr & Badlands @ Dr
Could you link the original thread on using these
