Onboard security and concealment
Valhalla War Machine
MikieG
Overland
88 Pontiac Fiero GT, 2022 Ford Bronco
Hornady has made a safe that absolutely and perfectly fits the rear cargo area of the two door Bronco.
It can be bolted into the vehicle using the cargo loop locations.
The vault has multiple entry options.
1. a standard vending machine key
2. a 4 - 6 digit combo
3. a RFID chip
b. electrical power comes from either. a 110v adapter or an internal bank. of AA batteries.
If your longer tools are 40 inches or less you can get three of them secured.
It can be M4, MP5 etc. There will also be room for any standard tool belt with equipment and a hole puncher.
Ford Bronco Onboard security and concealment 20251003_094847
Desert_Brush
SoCal
2015 Mini Cooper
What model safe is that? I need this more for when I have the top.
X-Rack
Nick
Bethpage, NY
2022 Ford Bronco
Looks like a perfect fit
SoDak1623
Cole
South Dakota
1996 F150, 2022 Badlands MT
If that can be anchored to the hard points that would be awesome. It also appears like it would level the load floor when the seats are down.
Rivers90
Ben
Southern California
2 Door Base Sasquatch
Again.... no options for the "4-drawer" Bronc models? I swear you 2-door folk are trying to take over the world! Blasphemous...
I think Ford makes one like that for the 4 door. I have a friend with one that I think he got from Ford. It even says bronco on it. The Ford one has 4 tiedown loops on the top.
How hard is it to get to the jack under it?
broadicustomworks
Hanging Rock, North Carolina
BUCKYBRONCO2021
Long Island New York
2021 Bronco Outer Banks thats been Squatchified
MikieG
Overland
I do not plan to use the cable. It appears that you can slide it all the way to the rear seats and cock it slightly left.
This allows the door to open with out contacting the cargo door pin.
If you do this, you can drill holes corresponding with the cargo tied downs nearest the rear seats.
It you want it forward, you will needs a corner mod to the vault door, or remove some metal from the bottom of the Bronco door pin.
If you are having problems finding this handy lil man box, call 8003383220
Ford Bronco Onboard security and concealment 20251003_095117
MikieG
Overland
Here is a list of retailers that show to still have this.
AR Gunlocker - No. 98190
Missouri $399.
https://stores.sportsmans.com/sportsmans-warehouse/us/co/parker/18420-cottonwood-drive. (303) 840-2321 $399
(828) 633-3182. (540) 366-9700. (814) 806-1997
(435) 634-7300. (208) 542-1900
(406) 586-0100. (208) 884-3000
(818) 797-6500. (541) 693-5000
(707) 585-1500. (541) 732-3700
(503) 777-8700. (360) 604-8000
(503) 589-0800. (503) 844-9100
Model: 98190 1536710
UPC: 090255981902.
Safe vault pros 888-850-9323
MikieG
Overland
It seems this discussion suspiciously and abruptly ended. In the off chance I'm wrong here is the conclusion.
To make it work you will get two bolts, maybe three of the rear bolts to lock it into the truck.
Ford Bronco Onboard security and concealment 20251005_172451
BUCKYBRONCO2021
Just picked up the ford lock box for the 4 door. Goes in the back. Got it for 25% off with fords black friday sale. Lowest price i could find it for 671 out the door shipped with taxes included with code member2025
will let everyone know how easy it is to put in. Im pretty sure its a cinch.
https://www.ford.com/product/cargo-area-security-drawer-4door-p2889833180
Ford Bronco Onboard security and concealment 1763844775831-n1
KABQ
Aaron
Albuquerque, NM
For further concealment I cut up a Ford Maverick bed liner, and now "there's nothing to see here." Plus it's really easy to remove if I need to stuff someone in the rear seats.
Ford Bronco Onboard security and concealment PXL_20250330_193901955
Ford Bronco Onboard security and concealment PXL_20250330_194049379
