Offset question
Buckin' AYE
Brad
So Cal
535d M Sport
Hey fellas and fellette's, I am looking to up grade the oem wheels on my '23 Wildtrak. I want to stick with 17's, but I want a more aggressive offset. Would 17x8.5 with a -10 offset be too aggressive? I think it should be fine. I want to make sure before I order them. Thanks, Brad
I have heard of people going with negative offsets before, and a mild -10 you would probably be ok. Most people recommend not exceeding somewhere between +12 and 0 though due to the scrub radius issues.
JL8jeff
Ewing, NJ
Here's a couple of pictures I grabbed off here with 17x8.5 -10 offset wheels on a truck with Sas flares. They will poke out some but it's not too bad.
Ford Bronco Offset question bronco_17x8.5ray10
Ford Bronco Offset question bronco_17x8.5ray102
87-Z28
Andy
BMW
If you are wondering how offset affects both scrub radius and mechanical trail then here are some plots. Otherwise just ignore.
Ford Bronco Offset question IMG_6822
Ford Bronco Offset question IMG_6823
Ford Bronco Offset question IMG_6825
Ford Bronco Offset question IMG_6824
Buckin' AYE
Buckin' AYE
Brad
So Cal
535d M Sport
Thanks guys! I appreciate your efforts! I'm going to go ahead and order them!
