Yet Another Offset Question...
NathanW
Nathan
FL
NA
Logan@Lethal
Logan
Hilton Head Island
www.lethalperformance.com
2022 Ford Bronco Wildtrak
OB w/SAS.
I'm looking at Fuel Covert or Fuel Zephyr wheels and they come with either +1 or +20 offset ( 5.04 & 5.79 BSM ) on 9" wheels. I'd like close to the factory look or just a bit more poke.
These two examples are about perfect. One is +18 offset and the other is 0, so I'm confused by this.
992b007e-f8df-47f8-b25e-1ffb9c4489be-jpeg.218626
2c8ccf00-bea3-43b4-83dc-47743c30d402-jpeg.219959
Thank you.
Nathan, feel free to send me a message and we can find the perfect wheel for your Bronco here at www.lethalperformance.com! We are Fuel wheel dealer!
-Andrew@Lethal
Bonnie6G
Kyle
Denver
Badlands LuxSquatch
If you’re looking for sas factory look with just a bit more poke, then go with the +20s. If you want even more poke after that, then you could swap fender flares with the non-sas version.
NathanW
Nathan
FL
NA
Thank you for that.
As an aside, is there a simple explanation as to why the +18 and 0 offset wheels in the pictures I provided both have the same amount of poke?
PWillette
Parrie
Maine
Thank you for that.
Mostly from camera angle...your only talking 18mm difference so +/-3/4"
Bonnie6G
Kyle
Denver
Badlands LuxSquatch
Thank you for that.
Likely a camera angle thing, but also not sure which wheels and tires those are. Different width wheels and different width tires can create different looks, but the outer surface of the wheel itself should be out .7” further on the 0 offset when compared to the +18 offset
NathanW
Nathan
FL
NA
Thanks for these responses. They're probably tiresome to answer over and over, but for someone like me that just doesn't understand it, it's really hard to make a decision. I feel like I can now make the right choice.
