OEM Soft Top compatibility?
BruceWayne22
Allison
Maryville,TN
‘22 Bronco
Has anyone swapped the Raptor for a soft top to confirm it works? I have one for my BL and will either sell it or have a two top trade in when the Raptor comes in if it doesn’t fit.
Soundwave
MA
2016 Focus RS
I believe they just put out a service bulletin or something similar. (TSS?) Saying the stock soft top will not fit a Raptor.
BruceWayne22
BruceWayne22
Allison
Maryville,TN
‘22 Bronco
Oh thanks! Do you know how I might find it?
Soundwave
MA
2016 Focus RS
Ask your dealer's service department. I just happened to hear it from a tech today. @BruceWayne22
Morrisattack
Hagerstown
BRONCO AND BRONCO
Oct 11 2022 2022 Bronco - Raptor - Not Soft Top Compatible
2022 Bronco Raptor vehicles are not soft top compatible. The soft top from other trim level Bronco vehicles will not work on the Raptor application as there are unique attributes to Raptor that prohibit it such as interference with the spare tire.
‘21OBX
90Bronco19
2022 bronco outer banks
Interference with the spare tire? That makes zero sense I have 37’s the top sits flush with the tailgate. I’d give it a go if you already have a softop. Worse case sell the soft top if it won’t work.
erniecombs
Ernie
1974 Bronco
Ford Bronco OEM Soft Top compatibility? Soft To
I've installed two factory soft tops now. One on my 2022 Raptor and another on a 2021 Badlands. The installs were the exact same. Absolutely zero clearance or compatibility issues with the Raptor. The installs were the exact same. Let me know if anyone wants any additional photos.
raptorusmaximus
Horicon Wisconsin
2012 F-150 Raptor
I've talked to besttop multiple times, no, the regular bronco softtop from ford ( they make it ) does NOT fit the raptor, No they don't have any plans to make one........
SUCKS.......
erniecombs
Ernie
1974 Bronco
I think that there is some confusion here. Maybe it's just me.... haha There are technically two "Ford" soft tops. One that's made by a company named Webasto who also makes the hard top. The Webasto soft top is ONLY available by ordering a soft top Bronco from the factory. The second soft top is the soft top that Ford sells as an option to purchase individually. This soft top is made by BesTop
The Webasto top fits the Raptor 100%.
lleege
Luke
Rochester, NY
Bronco Wildtrack, Bronco Raptor (waiting)
Curios why the bestop wont fit the raptor?
Raptor911
Raptor911
Broadlands, VA
what happens when you fold the soft-top all the way back. I assume it would hit the 3rd brake light and tire as they are higher on the Raptor?
BTW .. where are you in VA?
erniecombs
Ernie
1974 Bronco
It doesn’t hit the brake light. It’s good. I can take a photo maybe this weekend. Yes I live in Richmond.
Raptor911
Raptor911
Broadlands, VA
When a customer orders a dual-top what soft-top do they get? Do they get the Webasto or BestTop?
Ryan Feilner
Ryan
Omaha, NE
Mind helping me with a little issue I'm having....
I bought a 2021 OEM soft top off someone for my late 2022. The mounting holes on both sides do not line up at all.... Can you maybe help out with your experience...
I just posted the issue on the forum. Am I missing something...?
https://www.bronco6g.com/forum/threads/soft-top-mounting-holes-changed-on-newer-bronco.68641/
