OEM Roof Rack Mount
JoshFisk3
JoshFisk3
Josh
Peoria, AZ
2022 Base Bronco 2DR
Thank you but I think at this point I'll be pushing forward producing it myself unless a manufacturer reaches out to me. When the prototype arrives and I can verify it fits perfectly I will open the preorder.
JoshFisk3
JoshFisk3
Josh
Peoria, AZ
I could also open a preorder/batch for the crossbar mount if enough people are interested. Would be a similar deal with 25 pairs. The crossbar mount is complete and have verified the cnc version fits perfectly.
JoshFisk3
JoshFisk3
Josh
Peoria, AZ
Just made the preorder for the crossbar mount live incase someone wants those as well. To be clear I'll be holding off ordering until the preorder fills.
mykoljay
North NJ
2021 Bronco 2DR
Wait i didnt already miss the pre-order, did I?
Shows out of stock.
nevermind, I see crossbar is available, not the side. Will wait for those. Thx!!
JoshFisk3
JoshFisk3
Josh
Peoria, AZ
Final prototype came in today and fits very well over the side rail. Finish is consistent all over and threads are not affected by the anodizing. I'm happy with it and as of this post I have opened up the preorder. Slight change to the preorder is I've changed it to be a preorder of 50 individual side rail mounts instead of 25 pairs. Each will include the M3 hardware to secure it to the rail, an M3 allen key, and three 1" hex head bolts.
There is a slight increase in wind noise to be expected, however it isn't very much more relative to how much wind noise there already is. I would recommend installing the bolts even if nothing is mounted to limit any potential whistling sounds.
Please note that I do not plan on ordering until the preorder is filled I want to be as clear as I can be on this to not set the expectation it is going to be shipped next day. I know this seems weird but it's just myself offering these and I'm trying to avoid being stuck having 50 side rails mounted to my personal Bronco. Once the 50 preorders fill I will place the order with the manufacturer and will have a more solid timeline on shipping things out. If there are any questions please let me know and I'll try my best to answer.
For all the support you have all given me on getting this mount made and as an incentive to share the mount to help fill the preorder, the code "Bronco6g" can be used at checkout for 5% off.
Here is the link to the side rail preorder on my site: https://www.joshuafisk.com/product-page/jf-bronco-roof-rack-side-rail-mount
Ford Bronco OEM Roof Rack Mount IMG_7124
Ford Bronco OEM Roof Rack Mount IMG_7123
Ford Bronco OEM Roof Rack Mount IMG_7121
mykoljay
North NJ
2021 Bronco 2DR
Ordered 2! Look forward to figuring out how to mount snowboard on this at an angle.
Mudlight
Brent
Badsquatch
How high do these stick up past the roof rails? I am fighting clearance issues with my garage entrance.
JoshFisk3
JoshFisk3
Josh
Peoria, AZ
With a hexhead bolt it's going to stick up 1" 1/2 above the siderail.
HeHateMe
San Antonio, TX
2020 Hyundai Palisade
Are there example use cases that could be shared? Or products that could be used with these?
This might get more people interested by seeing the possibilities...
JoshFisk3
JoshFisk3
Josh
Peoria, AZ
For me personally I will use both side rail and crossbar mounts to mount high gain directional antenna. But anything from lights, hooks, jacks, awnings, or really anything that will bolt to it. I've also been toying around with a starlink dish adapter but no real progress to show on that as of now.
JoshFisk3
JoshFisk3
Josh
Peoria, AZ
Unfortunately, looks like there is no way to get to the preorder numbers after a few weeks being live. If you have placed an order thank you for the support but your order has already been refunded. If you'd still like to purchase a mount you can still do so through a sharing feature on PCBway, which is how I was able to get the machined versions. Following the links below you can order whichever mount you want, in any material/color. For reference the side rail mount is bead blasted, 6061 aluminum with a clear anodizing. PCBway has various qualities of different metals to choose from. All you need to do is follow the links and add to cart and select the materials and quantities you are looking for. Also since this is just the CNC service you'll need to purchase the M3 hardware elsewhere but I do have links to those in the posts on PCBway. If you do end up getting one it would be cool to see what materials and color combinations you chose. I personally may order a gold side rail mount at some point in the future.
Siderail Link:
https://www.pcbway.com/project/shareproject/Ford_Bronco_OEM_Roof_Rack_Siderail_Mount_ca2b5ae3.html
Crossbar Link:
https://www.pcbway.com/project/shareproject/Bronco_Crossbar_Mount_db867eb6.html
HeHateMe
San Antonio, TX
Siderail Link:
Crossbar Link:
I'm a bit lost using that site. Never ordered anything from them before.
Sad to see this didn't pick up steam... Did you post on Facebook as well?
JoshFisk3
JoshFisk3
Josh
Peoria, AZ
Just took a look at the PCBway site and thank you to whoever donated but that is seriously not necessary and I didn't even realize it was an option. I thought I'd go over the process of ordering from their site. Here is a link to a video of my showing the order process . I am not affiliated in any way with PCBway so I'm not shilling this is just the exact method I used to get the cnc prototypes. Instead of trying to sell these on my own I thought this would be a good route. It will likely be more expensive the the instant price as someone needs to manually look over and approved/adjust the price to manufacture the piece. After it is approved you can pay it will be made with whatever finishing/material options you select.
On another note, I have been working on replicating the hood tie downs to make them out of solid aluminum. I've got the mounting holes lined up, and now I'm working on adding in accessory mounting options. I would imagine this will be quite a bit more expensive to have machined but would probably look really sweet on the hood. If I end up ordering some for myself I will be sure to add them on PCBway as well.
Ford Bronco OEM Roof Rack Mount unnamed (5)
JoshFisk3
JoshFisk3
Josh
Peoria, AZ
The quote on getting a machined version of the hood tie down was 1k usd each so for now I will just use plastic if I want to have my version on there. I figured I'd also share those files here if anyone wants to make something of their own with it. It looks very similar to the above picture other than several more holes for mounting, some cosmetic changes, and changes of the mounting locations for better fitment. Here is the google drive link to the stl file for it which can be sent to any 3d printing service.
JoshFisk3
JoshFisk3
Josh
Peoria, AZ
I've decided to list the files for sale on cults3d to allow anyone to either send them to a machine shop or a 3d printing service online. I have the links to the crossbar mount, siderail mount, and hood tie down below. An easy to use 3d printing service I have used in the past is https://craftcloud3d.com/. Probably my last project for the Bronco for a bit as there are other things I'd like to work on.
Siderail Mount Link: https://cults3d.com/en/3d-model/gadget/bronco-oem-roof-rack-siderail-mount
Crossbar Mount Link: https://cults3d.com/en/3d-model/gadget/bronco-oem-roof-rack-crossbar-mount
Hood Tie Down: https://cults3d.com/en/3d-model/gadget/bronco-hood-tie-down
