Octane and Power
nwardoh
Richland Center, WI
2023 Bronco
So my '23 f150 with the 3.5 makes a lot more power running 93 and respectable gains on 91 e0. Will the 2.7 be the same way? Picking up my wife's new whip tomorrow.
OBXBRONCO
mike
Bath NC
2023 Bronco Wildtrak
I feel like 93 makes a difference though I've only ran one tank of 87 when i first got it. Ran 93 ever since. 7500 miles so far. Trip 1 average has been 19.6 mpg since new. Check every tank and they're ranging from 20 to 22+. All types of driving but mostly highway commutes with occasional dirt road riding and several beach trips. 22.3 so far on this last tank. Calculator checked several times. always within a couple of tenths. 2023 wildtrak so of course 2.7 auto and 35s.
Aonarch
Jack Hoff
MT
‘23 Bronco OBX 2DR Lux 2.7, ‘24 V60 Polestar
Ford lists this everywhere...
Yes, both the 2.3 and 2.7 have moderate power increases with 93.
A very small amount of vehicles actually have the hardware (Octane sensors) and/or software (Fuel maps, ignition timing, etc) to do this.
Ninjak
Miami
I run 93. I also have a tune and mods. yes, I make more power. And it's fun.
cbrenthus
Western PA
'22 BadSquatch, '02 T/A
Actually, most, if not all, vehicles for the last few decades have knock sensors and retard the timing if preignition is sensed. On my '03 Sentra Spec-V it was a big deal because the knock sensor was overly sensitive and would rob the engine of power even with 93 octane. When I had an '11 Camaro SS, a common issue on the forums was from dealers that put in regular fuel before delivery, causing knock and retarded timing, and the computer wouldn't switch back until you removed a couple fuses overnight.
The other important thing to note is that if you run 87, the engine will sense the knock and retard the timing so it goes away, however, preignition has already occurred which is not good for engines.
My simple answer is that I always run what the manual says to run. Most vehicles I've had did not call for premium, so I ran regular. But if it says premium, or premium is best for performance, then I run premium. ;)
Aonarch
Jack Hoff
MT
Yup!
I am running 93 during the summer to help prevent preignition, and will switch to 87 in the winter.
Gtrekker
Gary
NJ
Not sure you can quantify the difference with the seat of your pants n pedal on a stock setup.
Once you do some upgrades and mapping that requires the higher grade is when you will enjoy it more.
Till then... the engine will run cleaner which is a good thing to.
Tacanta14
Wasichu
Pie Town, NM
2022 Black Diamond 4 Door 2.3 MT
I'm at 7800', and rarely drive below 4500', so I use 87 all the time. Averaging about 21.5 mpg overall, but usually 24.5 when I'm not towing my 2000 lb teardrop.
1st 75th ranger
jeffrey
nj
i run e85 instead seems to run better then 104 octane i was running
