Non-Issue: Rotor rust
Greenie
Ford Bronco Non-Issue: Rotor rust 01538C66-F46A-4593-87D6-C26E59A36A84
Ford Bronco Non-Issue: Rotor rust 6079C8AF-9404-463E-8092-C6923533A16B
Ford Bronco Non-Issue: Rotor rust 5B04B7F6-E77D-4248-BCD7-FCDFCD570BA5
I have a Base that has Badland wheels/tires installed.
Classic28
Brandon
Maryland
Nissan Titan
That’s your rotor. Manufacturers put a light coating of paint to prevent rusting and it looks like some of yours chipped off.
KABQ
Aaron
Albuquerque, NM
Normal
Greenie
Greenie
Thanks guys.
Only have owned since October ā€˜22, so didn’t know if it was something that needed to be addressed to prevent it from getting worse.
RagnarKon
Ford Bronco, Escape, Focus
Thanks guys.
Naw... no need to worry.
Rotors are "wear" parts... they whole purpose of a rotor is provide a friction surface for the brake pads to scrape against to slow down the vehicle. In an ideal situation the brake rotor will last the life of the vehicle, and only brake pads will need to be replaced. But realistically you'll probably have to replace the brake rotors at least once or twice throughout the life of the vehicle.
If you want you can remove your wheel and spray paint the the surfaces on the rotor that don't make contact with the brake pads.
USAGUY
Ny
. Aggravating to look at……YES! Normal?……..
Yes
Suggestion………. Stop looking.
