No Upfitters? No Problem! OEM Style Switch Panel for Overhead
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
So I wish this was a thing back when we built our Bronco... because we got an Outer Banks with no upfitters and I ended up installing a switch panel by the shifter. It did the job but wasn't as clean as a solution we've had in the F150 world for YEARS.
That solution? The SwarfWorks Switch Panel Mount with either the AuxBeam switch system OR Diode Dynamics Switch System.
This mount replaces your sunglass holder (I know I know, I wear glasses also but it's worth giving up that spot) and gives you a really OEM looking spot to mount either an AuxBeam 8 Port Switch Panel or Diode Dynamics Switch Panel.
Installation is PRETTY straight forward. Just a bunch of bolts to remove to drop the top plastic trim panels so that you can route your wire and install the panel. Otherwise it's not bad at all.
Best part is you now get 8 switches over the OEM 6 AND you get MORE POWER (Insert Tim Allen grunt here). The AuxBeam and Diode Dynamics panels can put out a LOT more power then the factory upfitters ever could. Plus you can do bluetooth/phone control and/or strobe lighting as well.
Grab one of our kits here and don't forget to add-on either an AuxBeam Panel or Diode Dynamics Panel!
https://www.4x4truckleds.com/swarfw...-f-150-2023-ford-super-duty-2021-ford-bronco/
Ford Bronco No Upfitters? No Problem! OEM Style Switch Panel for Overhead 1785159813203-do
