No Aux Switches? No problem
MandRautomotive
Mikhail
CA
If your Bronco did not come with aux switches, M&R has an awesome WIRELESS alternative for you.
https://mandronline.com/products/wireless-wiring-harness
Revolutionize the way you connect and power accessories in your vehicle with our wireless wiring harness. Designed to enhance convenience, safety, and efficiency. Take the hassle out of traditional installations, providing a seamless and clutter-free solution for your accessories. In the past, you'd have to run a wire through the firewall inside the vehicle, no more! With this super easy installation, you can connect up to 8 different accessories, wirelessly!
Wireless Connectivity: With advanced wireless technology, connect and power various accessories without the need for traditional wiring. Enjoy a cleaner and more organized interior. Wireless remote stays inside your vehicle without the need to run a wire through the firewall.
8 Switches: Total of 8 circuits: (2) 5amps, (2) 10amps, (2) 20amps, (2) 30amps
  • Max power: 1200watts
  • Max current Rating: 80amps
  • Voltage: DC 12V-24V
Plug-and-Play Compatibility: Installing accessories has never been easier. Designed with a user-friendly, plug-and-play interface, eliminating the need for complex wiring setups. Simply connect your accessories to the panel and you're ready for an adventure.
Universal Compatibility: Whether you're adding LED lights, off-road equipment, or other accessories, our wireless wiring harness is universally compatible. Seamlessly integrates with your vehicle's electrical system.
Enhanced Safety: Reduce the risk of electrical issues and potential hazards associated with traditional wiring systems. Engineered with safety in mind, featuring built-in safeguards to protect against overloads, short circuits, and other electrical mishaps.
Weatherproof Design: Built to withstand the toughest conditions, it is fully weatherproof. It has a rubber gasket around the fuse box and covered in epoxy.
Ford Bronco No Aux Switches? No problem inside the box
jon
Jonathan
UTAH
2003 Rubicon, 1989 Ford Bronco Eddie Bauer
This looks awesome, anyone install it yet?
MandRautomotive
MandRautomotive
Mikhail
CA
I have a few installation videos on the site. I really like the product and how easy it is to install accessories to it
