chuckwagon
jim
ohio
1987 Jeep J10
Msell71
Stilwell, OK
2023 Bronco
How difficult and expensive was it to add stock Aux switches if you dont mind me asking. thx
It was easy. Just followed one of the videos out there. I don’t remember. Maybe $500-600.
ORACLE Lighting
ORACLE Lighting
ORACLE
New Orleans, LA
oraclelights.com
Is there an option for different mounting? Nothing magnetic that I’ve tried hasn’t ended up in the floorboard while off-roading…
Having personally wheeled this in Moab, Sedona, plus thousands of miles of highway driving, never had an unintentional disconnect. The panel is cradled in the dock then secured by magnets so it's pretty solid.
ORACLE Terry
Terry
New Orleans, LA
Bronco, RAM TRX, Gladiator, Wrangler JL,
Looking for a seamless way to control your LED lights and accessories without running a mess of wires through your firewall? The Trigger Controller is the ultimate solution!
✅ Wireless Control – No need for bulky wiring, drilling into your dash, or making permanent modifications. Keep your Bronco clean and mod-friendly!
📱 Bluetooth App Control – Take control right from your smartphone! Adjust brightness, activate flashing or strobe effects, and even monitor your battery voltage in real-time—so you're never caught off guard.
Ford Bronco No AUX? NO Problem! Aux Switch Solution- TRIGGER Controller for Ford Bronco ORACLE_Lighting_Trigger_Remote_Bronco
Ditch the hassle of traditional switch panels and go wireless! Who else is running the Trigger System? Let’s see those setups! 👇🚙💡
Trigger 6 Shooter Bronco Package: CLICK HERE
Trigger 4 Plus Bronco Package: CLICK HERE
ORACLE Lighting
ORACLE Lighting
ORACLE
New Orleans, LA
oraclelights.com
We are out here doing some night wheeling in Moab, UT and made a quick video of the features of the Trigger 6 Shooter!
The 6 Shooter by Trigger is basically a super slick way to control all your vehicle’s accessories—especially lights—without having to run a bunch of switches and wires through your dash.
Picture this: six wireless-controlled switches that let you manage everything from a mobile app or a rugged wireless remote. No need to drill holes or snake wires through your Bronco just to flip some switches. It’s all clean, smart, and super convenient.
One of the best things? You can mount the switch panel wherever you want—dash, roll bar, wherever feels natural—and it’s fully programmable. Want one switch to act like a momentary button, another to be always-on? Totally doable. It even lets you dim your lights, set timers, and customize icons on the app!
It’s waterproof, rugged, and made for real off-road use!
OracleLights
New Orleans, LA
www.oraclelights.com
JustWideman
Justin
justwideman.com
Bronco Big Bend '24
Does it fit in the sunglasses spot that non-Aux bornc's get?
OracleLights
New Orleans, LA
Will the control system be for sale at Bronco Invasion in Wildwood?
Yes! We bring some Trigger products to every show we attend, but if we don’t have what you need on-site, we can always ship it to you directly from the event!
OracleLights
New Orleans, LA
Technically, yes. ** Sharing a few photos from our Bronco for a better visual for you. **
What we did, instead of losing our sunglass holder, we mounted the Trigger mount to the top of it.
This is what it would look like in your sunglass holder.
Ford Bronco No AUX? NO Problem! Aux Switch Solution- TRIGGER Controller for Ford Bronco IMG_1539.JPG
This is how we have it mounted above the sunglass holder. We used some screws to mount it which was super simple since its just a hollow spot.
Ford Bronco No AUX? NO Problem! Aux Switch Solution- TRIGGER Controller for Ford Bronco IMG_1541
Ford Bronco No AUX? NO Problem! Aux Switch Solution- TRIGGER Controller for Ford Bronco IMG_1540.JPG
Hope this helps! -Brittany
OracleLights
New Orleans, LA
You get total control with the rocker-style switches that are usable inside or outside the vehicle
Ford Bronco No AUX? NO Problem! Aux Switch Solution- TRIGGER Controller for Ford Bronco 54487485326_25abfb1d21_k
