New wheels and tires questions
dbattle
Northern VA
2011 Toyota Prius
One other thing. Awhile back I created a pdf with a bunch of people’s different OBX tire/wheel looks. I imagine it could give you an idea at least for the Wildtrack.
it’s a large file so I’d view it on a desktop.
https://tinyurl.com/OBXBroncoWheels
I have 0 offsets and a 12.5” wide tire, mine stick out about 1” from the Big Bend fender
JL8jeff
Ewing, NJ
Do you have a build thread? I am curious about your side steps and fender flares.
If you're asking me, no I don't have a build thread. My truck is a base Sasquatch with the factory hoop steps and brushguard. The wider flares are the stock Sas flares. I just went with different wheels/tires.
ncneil
Neil
2023 Bronco
I have Non-Sas OBX and put Nitto Recons 315/70 r17 on G-FX TR-19 Rims (17 X8.5 +18 offset) and hub centric rings. No lift. No rubbing. I removed the crash bars but I installed 4WheelParts alternative crash bars. I’m happy with the look and the height. Originally I had planned on a lift but the tires alone gave me what I’m looking for at least in the immediate term. Hope this helps.
This is a +18 Offset? Wouldn't that mean 18mm IN from the center?
JL8jeff
Ewing, NJ
Yes, but the stock wheels are in the +30 to +40 range so +18 will stick out more than stock which tucks in the most.
ncneil
Neil
2023 Bronco
i looked at that sheet in the first response and didn't realize that. The +18's look great I would like that!
