New Lamps
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
I just finished installing my Fog Pocket and Rear Bumper lamps from 4x4TruckLEDs. Went with Baja Designs across the board. The harnesses and brackets from 4x4TruckLEDs made the install pretty easy -- even with temperatures in the 20Fs. No, I don't work for 4x4TruckLEDs, nor am I affiliated with them except being a customer. Right now I'm controlling each of the fog lamps with independent switches. A fourth upfitter switch for the rear. Both pair of Squadrons in the front fog kit are SAE/street legal. S2 Sports are not. I haven't connected the rear lamps to the factory backups yet (wired 'or' with diode)... not sure I want to, but it's an easy tweak if I decide to do it.
Looks great! Thanks for the business.
Diode Dynamics
John C.
St. Louis, Missouri
www.diodedynamics.com
Ford Bronco
I dig the rear bumper lights. Been thinking about red ones for bad weather, and down low like that should work nicely.... wondering @Diode Dynamics has something. Haven't really searched it out....and easy to mount and wire for us non-mechanicals....would be nice to just add into fog lamps wired to the Aux switch together...
We do offer a Flush Mount Kit for the rear bumper with a red running light that comes with a full fused and relayed harness. However, it is not bolt-on like the on in the above images.
scojosmac
CO
f150 / bronco
You are getting whatever you pick. We let YOU, the customer, choose what lights YOU want. It's part of our "Build Your Own Kit" system we call it. You get the brackets, harness, instructions and then you get to choose 3 different lights in whatever pattern/light output you want. We go over, on our site, the various options and some recommendations as well:
https://www.4x4truckleds.com/baja-d...-w-kr-off-road-brackets-for-2021-ford-bronco/
Really wish your bracket was like BDs :(
nd2002
Seattle
'17 BMW M2, '18 Audi Q7
I've been wondering if there is a good marine grade/underhood junction block for the upfitter wires. Seems it would be good to have.
Look into Deutsch connectors, specifically the ones made for 10-14ga wire. That’s how I’ve set up the engine bay with the pocket kit I have. Very well made and easy to add/change wiring.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
We're working on one. I have the prototype (made from stainless steel) arriving to me Monday for fitment. But it looks like this (this is a 3D model I printed)
Here is a photo with Diode Dynamics (grin). We designed them to work with both Baja and Diode Dynamics
Ford Bronco New Lamps 1641573727109
Headsong
Great, just one more thing I want. That looks way cool! Thx, Adam.
JohnnyX
JohnnyX
Pentwater, Michigan
2024 Badlands Sasquatch, 2024 Explorer ST-Line, 2008 Explorer XLT
Do they have a terminal block set up, or just connectors. If just connectors, how easy is it to move pins around in the connector? My experience is that once a crimped pin is in the connector shell, it's not going to come out without damaging it.
scojosmac
CO
f150 / bronco
thats amazing new. Nice work, Adam. Rough time to being ready to sell/deliver?
4x4TruckLEDs.com
Adam
Lindenhurst, NY
nd2002
Seattle
It's sort of a hybrid, I suppose? Certainly not a block, but you can have a single connector support multiple hookups. For e.g. I have 2 lights connected to 2 aux switches using a single connector. You can choose 2, 4, 6, 8, 10, 12 pin connectors (depending on the wire gauge, different options available)
This is where I feel this connector shines. The pins themselves, and the crimping strength and quality is VERY high (though requires a separate tool), and the connector is designed for the crimped pins to be reconfigured as needed within the connector or even to a different connector.
There are many videos on YT that show you the full process like this
Diode Dynamics
John C.
St. Louis, Missouri
Ford Bronco
Looks awesome!
4x4TruckLEDs.com
Adam
Lindenhurst, NY
imaginager
PDX / Oregon
2021 Bronco Black Diamond
Here's the protype made from stainless (need to redesign it a bit)
BUT making progress!
Mostly unrelated question: I see BD offers Lens Kits for the S2 (and others). Can an S2 Wide Cornering Amber be converted with a Lens Kit to be non-amber and in any pattern? I'm thinking, specifically, for transitioning between seasonal driving. It's not foggy in the summer, typically, so it would be nice to be able to switch my fog light to a spot, or driving/combo.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Yes. Bajas lights are all white, so you can put any lens you want (clear or amber) in any pattern you want at any time. They call it "U-Service"
We stock all the lenses: https://www.4x4truckleds.com/led-au...igns/lighting-accessories/replacement-lenses/
Natai
Sean
Sacramento
Nissan Sentra, Mercedes GLC
No, I haven't. Inner lamp is 1 (Amber SAE), middle is 2 (White SAE), outer lamp (White Sport S2) is 3. The rears are on 4. It's pretty easy to move them around if I want or need to. I've been wondering if there is a good marine grade/underhood junction block for the upfitter wires. Seems it would be good to have.
I've spent a few hours this week looking for the same thing, without much success.
I'm leaning towards getting this 6-circuit 30A Blue Sea Systems terminal block and a weatherproof box that fits.
https://www.amazon.com/dp/B000277JA...t_i_H3WFTZBFYMPKGD8BBV3F?_encoding=UTF8&psc=1
