NEW: Improved Reverse Lighting with Extreme-Performance LED Reverse Light Bulbs!
OracleLights
New Orleans, LA
www.oraclelights.com
Dim reverse lighting can be dangerous and troublesome, especially when navigating larger vehicles like the Bronco. Rear lighting can be neglected for daily use and offroading, but having adequate lighting while backing up is important for the best experience.
Improve your visibility while backing up with the Extreme-Performance LED Reverse Light Bulbs from ORACLE Lighting -- available for pre-order now!
Ford Bronco NEW: Improved Reverse Lighting with Extreme-Performance LED Reverse Light Bulbs! seq3.00_07_42_11.Still002copy_1024x1024
These WT21W reverse lights feature vibrant 3020 LEDs for maximum illumination on some of the most popular models, such as the 2021+ Ford Bronco, Maverick, F150, SuperDuty, and more. With a 2196 Lumen output from each bulb, you'll enjoy a reverse brightness that rivals your headlights. The Kelvin color of 6000K-6500K provides a more modern look to the rear end and improves backup visibility at night. The onboard constant-current driver ensures increased reliability, and the anodized aluminum construction offers leading durability.
More photos here!
Ford Bronco NEW: Improved Reverse Lighting with Extreme-Performance LED Reverse Light Bulbs! 4911-001_AJ
The installation takes only a few minutes with a direct-fit, plug-and-play design and error-free functionality. Simply remove the existing halogen bulbs and replace them with these super-bright LEDs! This kit contains 2x bulbs for a complete reverse light conversion. Improve your rear visibility with ORACLE Lighting and enjoy superior performance when it matters most!
Ford Bronco NEW: Improved Reverse Lighting with Extreme-Performance LED Reverse Light Bulbs! 4911-001_AC_1024x1024
Bulb Specifications:
• Brightness: 2196 Lumens (Each)
• Bulb Wattage: 25W (Each)
• Amp Draw: 2A (@12VDC)
• Kelvin Color: 6000K-6500K
• LED: 27x 3020 SMD Chips
• Material: Anodized Aluminum
Product Features:
• Each Pack Includes Two (2) Bulbs
• Extreme-Performance 3020 LED Chips
• Constant-Current IC LED Driver
• Wide Voltage Input Range (10-60V)
• Direct Fit “Plug-&-Play” Installation
• 1 Year Replacement Warranty
These extreme-performance bulbs are available for pre-order now and will be shipping soon!
CHECK THEM OUT HERE!
Cfield90
South FL
21 Bronco/22 Escape/01 Softail/90 Bronco (former)
Looks like Oracle is going to be getting more of my money!
Herbie
Alex
Cleveland OH
2022 Badlands
I hate to be thick, but don't we already have LED's back there?
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Not I! Black Diamond isn’t graced with them. I’ve been running the Alla versions…I might have to compare.
1400 vs 2200 lumens…
Herbie
Alex
Cleveland OH
2022 Badlands
Ahhhh, I thought it might be a trim think. Thank you for clarifying.
redone17
Cold Spring, NY
Base and Black Diamond are stuck with standard. Big Bend you can upgrade. The rest of the trim the LED comes standard.
Raptor911
Raptor911
Broadlands, VA
Correct me if I am wrong BUT if you have non leds and replace with a LED then it will fast blink on you.
redone17
Cold Spring, NY
They don’t blink or flash or fluctuate at all for me. I’ve been running them since August.
AK SNO RIDER
Ty
Alaska
I'd be pretty impressed if you got hyper flash out of your reverse lights.
72BroncoSand
PNW
72 Bronco, 77 f-150, Jetta Tdi, 1ton
$39.99 plus $13.17 shipping. Almost ordered but figured id ask if you can add them to the triple fog lights i ordered to save on shipping.
AK SNO RIDER
Ty
Alaska
Is this Led vs led or is this Led vs non led? What are you running in the stock picture?
That's showing a comparison against the base taillights stock halogen bulbs. If you have signature lighting you already have an LED board and this upgrade is not applicable.
OracleLights
OracleLights
New Orleans, LA
Sure, message us your fog order #, and we can add these bulbs to that order for you!
AK SNO RIDER is correct. The "stock" is the halogen stock lights in our Bronco.
