- Joined
- Jan 21, 2021
- Threads
- 252
- Messages
- 1,061
- Reaction score
- 862
- Location
- New Orleans, LA
- Website
- www.oraclelights.com
- Vehicle(s)
- Bronco
- Your Bronco Model
- Base
- Thread starter
- #1
Dim reverse lighting can be dangerous and troublesome, especially when navigating larger vehicles like the Bronco. Rear lighting can be neglected for daily use and offroading, but having adequate lighting while backing up is important for the best experience.
Improve your visibility while backing up with the Extreme-Performance LED Reverse Light Bulbs from ORACLE Lighting -- available for pre-order now!
These WT21W reverse lights feature vibrant 3020 LEDs for maximum illumination on some of the most popular models, such as the 2021+ Ford Bronco, Maverick, F150, SuperDuty, and more. With a 2196 Lumen output from each bulb, you'll enjoy a reverse brightness that rivals your headlights. The Kelvin color of 6000K-6500K provides a more modern look to the rear end and improves backup visibility at night. The onboard constant-current driver ensures increased reliability, and the anodized aluminum construction offers leading durability.
More photos here!
The installation takes only a few minutes with a direct-fit, plug-and-play design and error-free functionality. Simply remove the existing halogen bulbs and replace them with these super-bright LEDs! This kit contains 2x bulbs for a complete reverse light conversion. Improve your rear visibility with ORACLE Lighting and enjoy superior performance when it matters most!
Bulb Specifications:
• Brightness: 2196 Lumens (Each)
• Bulb Wattage: 25W (Each)
• Amp Draw: 2A (@12VDC)
• Kelvin Color: 6000K-6500K
• LED: 27x 3020 SMD Chips
• Material: Anodized Aluminum
Product Features:
• Each Pack Includes Two (2) Bulbs
• Extreme-Performance 3020 LED Chips
• Constant-Current IC LED Driver
• Wide Voltage Input Range (10-60V)
• Direct Fit “Plug-&-Play” Installation
• 1 Year Replacement Warranty
These extreme-performance bulbs are available for pre-order now and will be shipping soon!
CHECK THEM OUT HERE!
More photos here!
Product Features:
