New Build Advice: Locker vs V6
Butzy
Butzy
Brookfield, Ohio
f150 & bronco
The 2.3 is a very powerful engine pushing out 300 hp on premium. That's twice as much as my 2.4L wrangler.......you don't need the 2.7 to wheel and you'll save some weight with the 2.3. I'd do lockers all day and you can also get your manual transmission and scratch that itch as well.
Butzy
Butzy
Brookfield, Ohio
f150 & bronco
Keep in mind that Ford sells the 4.46 locking rear for 2500 which can be added later if desired. Same ratio that would come on the base and black diamond manual.
Nate Train
Nate Train
Nate
Rifle, CO
Ford Mustang GT, Ford Bronco BD
Wait it out! Save more money and get what you desire! Don't settle!
But....I want it NOW!
Actually, that's sound advice, and I'm totally fine with waiting. I think, ultimately, I want a versatile vehicle that can do several things fairly well.
Calm horse
MO
Georgia
17 f150 king ranch
I originally wanted base squatch...but heated seats was a must...cost me thousands more but I love it
If yinz know yinz know
dodge charger
Definitely 2 door. Auto vs manual was strictly based on engine option. If it's the I4, I was staying with the manual. I'd like the advanced 4x4 but not the Sasquatch. Guess I'm doing without advanced 4x4.
4dr BD 2.3 manual owner here, just adding my $0.02 to say you won't be disappointed in the 2.3 manual. Like others I'd see if you can swing te advanced 4x4
‘21OBX
90Bronco19
2022 bronco outer banks
Just sold out ‘21 with v6 and kept the 2.3 4 cyl. Get the locker it gives you 4.27 gearing and no FAD(front axle disconnect) that I’ve seen fail on a few occasions. The 2.3 has plenty of power and I actually find it more fun to drive around town. The only place I could really tell the difference in motors is sound and freeway merging or passing. As mentioned base Sasquatch is the best value out there for off roading but if it’s not in the cards go BB with locker.
Nate Train
Nate Train
Nate
Rifle, CO
Thanks for all the tips. I ended up just spending a little extra for my original idea: 2 door Black Diamond, if anyone was curious.
Ford Bronco New Build Advice: Locker vs V6 Screenshot_20230327-121309~2
mpeugeot
So 2 door V6?
Nate Train
Nate Train
Nate
Rifle, CO
So 2 door V6?
No, I went 4 cylinder. The only thing I added was the automatic, but wouldn't have done that had it not been required.
mpeugeot
Ya, the situation with the manual transmission is kinda fucked.
Beachin 74
Delaware
Peep this. This guy is running a Open diff (no locker) white 2dr Base i4
with a stick shift. On the most rough trail there is. All he has is a lift and tires.
I can almost smell the clutch watching that video. What happed to low range and the crawl gear?
Nate Train
Nate Train
Nate
Rifle, CO
You can option 4A on the Black Diamond so it's actually usable in the winter...
Well, it looks like my dealer did that, even though we didn't set that up when we built it a couple days prior to ordering. But I've gone in there and changed it a couple times, so it was probably left over from an earlier iteration. I'm cool with it.
Not sure if it was a Ford thing or my dealer did it, but they also knocked off $250 under "AM/FM 6 Spkrs SDAR." Don't know what that's all about, but...
