New Bronco Owner!
ThunderFlash
Doug
Washington
'24 4-dr WT, '22 2-dr WT, '15 Explorer Sport, '02 F250 SD V-10
Where should I look for aftermarket interior accessories?
Not completely sure the Braptor is as bad, but the interior lighting on both our Wildtraks was absolutely miserable. We loved our 2 door WT so much, we bought a 4 door WT before they disappeared. Here in the PNW we live much of our lives in darkness, so one of the first mods on the 4dr was the Mabett rear and side overhead lights off Amazon. They worked out so well on the 2dr, it was a no brainer on the 4dr. I think IAG has them, too. I suspect they are from the same place in China, but can't say for sure. It's an easy plug and play install. Not the most exciting mod, but it's a significant improvement in livability of the Bronco if you have any form of night life.
Hope the links work...
https://a.co/d/206Hg7K
https://a.co/d/eHwqGet
Ford Bronco New Bronco Owner! PXL_20240922_033604426
Ford Bronco New Bronco Owner! PXL_20240925_045144379
theblackangus
Right in the middle
25 Badlands, 2020 Corvette, 2011 BMW 1M
A fuse map on the fusebox should come from the factory. Good to see there are options to add it. It looks like the fuses may have changed for 2025? do you know what changed?
I dont, but Im going to validate with the user manual once I get it and make any corrections needed.
And yeah you'd think it would be a sticker that comes with the vehicle, but since its not.... and the engine compartment one comes in etched acrylic so it should last well in the heat.
Kitae
Kitae
Christina
Galveston
2025 Bronco Raptor
Not completely sure the Braptor is as bad, but the interior lighting on both our Wildtraks was absolutely miserable. ✓
Thanks for sharing your experience and recommendations, lighting is definitely on my list!
MandRautomotive
Mikhail
CA
Hey guys, if you are looking for some bad ass light bar kits you can use coupon code COLBY10 at checkout to get 10% off. Let me know if you have any questions!
Ford Bronco Raptor Light Bar Kits
Ford Bronco Light Bar Kits
Here is a couple of quick installation videos to show you how easy our kits are to install yourself.
DrillRX
Bakersfield, Ca
2024 Ford Bronco BB SAS 2 Door 6 speed
One of the first "mods" I did was getting Forscan. There are SO many things you can change about how your vehicle functions, you can make it just how you like it. From turning off the start/stop function, up AND down windows with the key fob, having your fogs stay on with high beam lights, adjusting the volume/power to the different speakers/zones, disabling the seat belt minders, to something as little as the turn signal "click" volume, or even adding/subtracting goat modes (why you'd want to disable a goat mode i don't know but you could do it). Even changing the TPMS warning pressure level so when you air down at the beach its not nagging you the whole time.
One of the cheapest and most useful mods to start out with. For around $50 for the cable and $50 for Forscan and a laptop, it makes your vehicle feel like it was built just for you.
Beach_Bum
Ken
St. Augustine, FL
2023 Outerbanks Bronco
Back from our first trip with her, decided to take her to the beach so she can see her new home!
Congrats on your Bronco.
Since your primary use will be on the beach, I would recommend Salt Shift or other similar products for your cleanup and maintenance. Even if you never drive in the water or runnels, the sand is loaded with salt. The salt/sand will get in nooks/crannies and you want to thoroughly flush the undercarriage.
@Underground Graphics is located in the Houston area. Underground Graphics
helifino16
Ron
Mount Sinai, NY (Long Island)
Howdy!
Get all-weather mats. 3W liners has a great set - search Amazon. So much better for removing and shaking out the sand. Highly recommend the Cargo mat for all those sandy items you toss in there. Enjoy!
theblackangus
Right in the middle
Helifino16's suggestion for aftermarket mats is a great one, first thing I bought. I would encourage looking at weathertech for front and rear mats. Reasonably priced for the very high quality... and they support the automotive scene significantly with the money they make.
