Need some help: Dealer possibly ruined back window
Guardian1fox2
Guardian1fox2
Jacob
Louisiana
2022 Bronco Black Diamond, 1923 Model T Racer
I’m still waiting on the drivers side tension cable to be replaced, it was broken. Ford has it back ordered supposed to ship the 27th. Been one thing after another. Crazy back window is so expensive when you can almost buy a used “new” top on here for $800 lol oughta tell them to just come on here and buy me a top and fix all the problems 😂
Guardian1fox2
Guardian1fox2
Jacob
Louisiana
Just heard they’re gonna order me a new window! I’m glad they’re doing the right thing. Really bothered me it was messed up cause I would look at it every time I walked around it.
BulldogBear
Scottsdale
2021 Ford Bronco Badlands, 2000 Mercedes-Benz G500
I generally dislike the promo stuff dealers do like license plate holders and adhesive stickers on a rear panel, but they are at least reasonable (and I forgot to warn them not to put a label on the tailgate so I live with it).
I've always wondered why people leave the tacky dealer license plate covers on their cars forever.
To remove the dealer badging/decals, all you need is some dental floss, goof-off or WD-40, and some patience to get them off. The sooner you remove them the easier they are to get off.
JAricB
MN
540i, Rubicon, Bronco, TRX
I think it looks pretty cool!
Lowcountry Bronco
William
South Carolina Lowcountry
Yep, dealer owes you a rear window.
Ford Bronco Need some help: Dealer possibly ruined back window wtf-is-that-confused
anl
andre
california
2021 bronco
Why would you put the temp tag in the rear window of a soft top anyway? Top goes down you can no longer see temp tag!
every jeep or convertible I ever owned,the temp tag has always been out in the rear license plate holder
ITS SIMPLE,THE DEALERSHIP PUT IT ON ,U SHOULD OF, HAVE THEM REMOVE IT,BEFORE U DROVE OFF THE LOT.
flip
Phil
IN
www.ruxerparts.com
Fords
Anyone that was a Jan build and held needs to check the back windows as well. Some genius at Ford was writing on them with a paint marker which leaves a shadow either from the paint or the solvent in the marker. It's hard to see but the scratches in the upper left corner where they tried to wipe another set of numbers off will give it away. The writing will be just to the right of the scratches. Have to look at from an angle since it's hard to see straight on.
Deltamav
Ben
Cherry Hill, NJ
2022 Badlands
It's hard enough to see out the rear window with the headrests and the rear tire in the way, and yet they added a sticker right in the middle? Morons.
Guardian1fox2
Guardian1fox2
Jacob
Louisiana
They are indeed ordering my new rear window! I’ll keep this one as a spare…just in case never know lol at $750 that’s just ludicrous IMO, but it won’t go to waste. Especially if someone ends up needing one to get by.
Techun
Pa
BD, 2.7, MIC, 4dr
You mean the black Diamond ones on the side? I though of removing those. Maybe get just a classic bronco one but kinda like no emblems
Floss for raised 3d badges. The side ones I think are just stickers
Bradnewt
Brad
Hot Springs, Arkansas
Jeep Wrangler
My Bronco came with a dealer sticker on the window as well. I removed it as soon as I got home. My window had the same imprint as your window after sticker removal. I'm not sure how long it took, but you can't tell a sticker was ever there. The vinyl will relax over time. The summer sun and heat will speed things up.
Guardian1fox2
Guardian1fox2
Jacob
Louisiana
That’s good to know, since I’m getting a new one for free, I’ll take this one when I swap and lay it out in the sun on a hard surface see if it does. Then I’ll just have a spare.
JinKat
Jin
Iowa
2024 Outer Banks 4 dr
Any suggestions if dealer won’t replace the window even though they put the temp plate taped to the pvc window? I’m super pissed but they won’t do anything for me.
Ford Bronco Need some help: Dealer possibly ruined back window IMG_4168
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hi there, Jin. This back window concern doesn’t sound like something we want you to experience with your Bronco. Could you please send us a PM with your VIN and the name and location of your Ford dealer? To send a private message, just click on our username and select "Start Conversation". I'd be happy to look into how I can assist you on my end.
Dral97
Ford Bronco, Wrangler YJ and 392, BMW 4 series
How in the hell can a sticker make an indentation like that? Did they use a heat gun or something to make it stick to the window?
Exactly. Seems like they knew exactly what they were doing. heh
Glady they are replacing it.
