Need help with spring parts number
screenid10t
22 Bronco Big Bend
I bought bilstein takeoffs + control arms from a 4 door 2.7L wildtrack and want to install it on my 2 door 2.3L/MT Big Bend without towing. From my understand base on the definite guide I would need front spring MB3Z-5310-J, and rear spring MB3Z-5560-A. Is this correct? Is there a difference between the 2.3L M/T and 2.3L auto springs? Thanks.
Ducati1098
No difference between manual and auto that I can see. Those spring numbers should be correct, but the shocks won’t be.
screenid10t
22 Bronco Big Bend
You are right, shocks does seem to be a different part number. Do you know what the difference is? Google states the the 4 door wildtrack has almost 500lb more then the 2 door big bend. I’m assuming the ride quality would be more stiff.
Ducati1098
I’m not sure what the difference is, but I would guess it would be more stiff also for the weight.
