Need help with rear fox shocks !!
turboelvis
Elvis
hiltown Pensilvania
2024 branco raptor
Hello, I got issue with Branco raptor rear fox boot being all mangle and out of shape . I read ar this forum some members got all new shocks replaced so I went local dealer and I was denied 🤦‍♂️ They told me it’s normal , but why some dealers do change when some not? What I shut do next ?
Ford Bronco Need help with rear fox shocks !! IMG_0179
Valhalla
Valhalla
Chattanooga Tn
Try another dealer, how many miles?
Sir915
Shawn
El paso
2023 Bronco
Wait is this really a issue? mine looks just like this but rides just fine but I always thought it looked a little funny
JohnGalt
Tahoe, CA
2023 Defender 110
I had one replaced under warranty in the first year. Both rear shocks bunched up again and I’ve just ignored it since. The boots aren’t really necessary and I’m not going to try to get them replaced every time this happens. I’m guessing Ford and/or Fox came to the conclusion that they’d go broke replacing these endlessly.
But at some point free replacement shocks under my extended warranty would be nice……
turboelvis
turboelvis
Elvis
hiltown Pensilvania
2024 branco raptor
I don’t think it’s big issue , but some members got new shocks under the warranty . It’s weird some dealers change when some not !! .
Tonka Bronka
Duncansville
F350, V60 Polestar, 900SS, K1300S, RnineT Racer
Can someone tell me why this shock is so coil bound?
It’s on a jack stand at max compression, and it’s a dual zone coil. So the top is pretty tight but there’s still compression room on the bottom half so it’s not totally bound.
Tonka Bronka
Duncansville
Six coils bound just by lifting a wheel in the shop? Seems odd.
23OBX2.7
AB Canada
2023 Bronco
Typical crappy aftermarket so stupid that boot is too large for spring ID its definitely warranty contact FOX directly.
The damper shaft now exposed to dirt and moisture not good of costly shocks thatbobly last 30-50K mulrs in first place.
ThunderFlash
Doug
Washington
'24 4-dr WT, '22 2-dr WT, '15 Explorer Sport, '02 F250 SD V-10
It's a Raptor, Fox's are stock.
I'm on the fence about boots. Yeah, they keep most of the stuff out, but once it gets in there, it stays in there.
23OBX2.7
AB Canada
2023 Bronco
It's clearly a defect even on a $20K vehicle, you could send a pic to Fox and ask if it's normal if say no take it to dealer, or just see another dealer.
