Need Help Fighting Dealer
BASE729
Boston
Long story short, I flew to pickup my Bronco several states away as it was nearly exactly what I was looking for with model/options. When I picked it up, there was a cheap plastic air deflector installed on the front of the hood (the type held on with 3M tape). I figured when I got it home I'd remove it, no big deal.
I got home and decided to get a stealth PPF wrap. The company doing the wrap offered to take the deflector off when they performed the wrap. They then texted me the large chip in the hood that the deflector was hiding.
We tried to get Ford touchup paint in that model, but every dealer within 100 miles was out of stock saying it was "impossible to get" (yet another reason for dealer to install deflector).
When confronted with all of this, the dealer requested a quote from a body shop to repair and they would pay the bill. I should mention, they charged me 5k over sticker due to some term I forget, but basically they're hard to come by so pay a premium.
To say I'm livid is an understatement. Before I get into it with the dealer, I was hoping to get a bit of info:
1. A cheap plastic air deflector is not a factory option, this is something only the dealer adds, correct?
2. There was no air deflector on the sticker, or anywhere in the paperwork. Dealers "never" throw in things for free, correct?
3. Has anyone seen a Bronco on a lot with this air deflector installed?
Ford Bronco Need Help Fighting Dealer 71528503094__F07E62D4-0C67-49EA-AC8E-90F8ABFFD230 (002)
chtucker
Kirkland, WA
FJ Cruiser
I don't see an air deflector...
It was there and they took it off (hence the double stick tape)... under the deflector was that paint chip.
You are probably not going to get what you want. How are they supposed to know that the chip didn't happen when the deflector was taken off. You already got taken advantage of by paying MSRP. cut your losses and go to your local competent body shop and get it fixed properly.
Dubsesd
Andrew
CT
04 Ford F-150, 06 Roush Mustang
Situation sucks…. But seems like they said they will pay for it and take care of it so nothing more to really fight about?
and to answer one of your questions, yes that deflector is an add on and does not come factory.
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
Before I read the full post from the OP, I thought it had occurred from removing the hood deflector as well. It's going to be difficult to prove one way or another unfortunately.
The hood deflectors are a dealer installed option, however when I asked my dealership to install mine they fed me a bunch of BS that they don't install them because then they're liable if they fly off and cause damage and the 3M tape is garbage blah blah blah. Essentially they just didn't want to do it.
If the dealership is looking for a quote from a bodyshop to fix it, get it for them and see what happens. I would just order the touch up paint and whenever it arrives, it arrives.
Strizzo
Houston, Tx
Lexus GX460, 1966 Mustang Convertible, Jeep Wrangler TJ
He asked "has anyone seen a bronco on a lot with this air deflector installed?"
There is a ford optional hood protector/deflector but I couldn't say how its attached, but it does look cheap and is made of plastic.
Blackcat
South Carolina
2022 FORD BRONCO BASE 2 DOOR M/T
If the dealer is willing to pay for the repairs, what's the big deal? Yeah, it's an inconvenience, but slow down. The dealer could've played dumb and told you to buzz off, but it appears they're trying to make right?
Rspayde
North Ga
2022 C/O Black Diamond
IDK i'd sell it man. But seems like the dealer is willing to pay for a repair so I guess delete this post and move on
Sandbergo
Jelani & Dave
Orlando
Rogue
Well as someone that works with Paint protection, if you use touch up paint you will still see the affected area. Only way to fix it and make it look like there isn’t contamination under the film is to have the paint fixed by a shop.
Imaginary Friend
Southern MN
A passel of Fords and a Jeep JL Rubi
Or order a Dr. Color Chip kit and move on with your life.
Somehow I ended up with a strange scratch/ding on the hood of my '19 F150 when it was new and had less than 500 miles on it. Probably a parking lot thing. I touched it up and installed one of those cheap deflectors (GTS), and I'm glad I did because Ford's paint is trash and chips easily. But the front of my hood looks great. Funny part is I pondered a deflector the day I bought the truck....
Reese
Reese 💁🏻‍♀️🇨🇦
CANADA
Bronco Badlands Lux 2023
No Broncos come with air deflectors.
It’s an after market option on Ford’s accessories section or independent suppliers. The buyer puts it on or a dealer could. Either way it’s not an option to select when you’re building a Bronco online or buying off a lot.
It will be hard to determine how that scratch got there and/or if in fact someone was trying to hide it.
It’s also called body armour. You can get other PVC pieces with 3M tape to cover different corners of the truck. All AFTER market/accessory items through Ford or independent suppliers.
But I agree with others. If the dealer is willing to fix it, then let them without confrontation.
They could have easily said no and walked. The short of it is, you have to go back to the dealership. They are your point of contact.
Don’t burn that bridge.
~Reese
Baja Bronco
2Sun AZ
Dealer willing to pay for it, so get it done. If you’re livid now, wait until you get more chips and broken windshields. It’s unavoidable. Your driving a shoe box, better get used to it.
Aonarch
Jack Hoff
MT
I don't want to jump to conclusions, but I think they covered up that chip with the air deflector.
That is disappointing... A good dealer would have just fixed it, no questions asked the second it was noticed on the lot.
Chritaka
DFW, Texas
'23 WildTrak; '06 Whippl'd Mustang (sold4upgrades)
The stock paint chips very easily. My first chip off-road I about fainted. Now I’m use to it. 🙂
Agreed! I had a Whippled 2006 Mustang in Tungsten Gray that I sold for mod $ when I bought the Bronco... That paint was solid and had 0 chips over 17 years and a lot of go-fast miles... I've already had 2 on the Bronco in 8 months! Luckily I found some CG touch-up paint at my local dealer...wet sanded and buffed it out .
