Need advice on floor jacks
XrayMike
Alex
Chicago, IL
2001 Jeep Wrangler, 2016 Ford Focus ST
I just purchased a 4 ton heavy duty jack and it won’t lift the tires off the ground. Scissor lift won’t do the trick either l. My bronco is sitting on 35s and a 2inch zone off-road leveling kit. What is everyone else using to jack up their broncos?
Deleted member 3063
Guest
Depends on how much you're short. a few inches, there are hard rubber blocks that fit on the saddle. There are different diameters.
If more perhaps your jack company has an extension kit. If not you need a different truck sized jack.
Me, I carefully use a piece of 4x4 lumber (they can split and fail) on my Raptor then jack stands, not recommended either way.
Ford Bronco Need advice on floor jacks jack
MNBigfoot
MN
Harbor Freight "Dayona low profile".
It's sold at a lot of places under other names, great jack for the money
tater_70
Terry
64 Fairlane, 1973 Bronco, 75 F-100
Great jack, has close to a 24" lift.
FrankenRodz
sheldon
Massachusetts
2022 Base 2 - Door
Sure you're using it correctly? Your truck only weighs about 2-1/2 tons.
Any floor jack will lift a vehicle close to double the size of a Bronco.
XrayMike
XrayMike
Alex
Chicago, IL
I might not be. I’m jacking it like a typical jack but I think I’m reaching its maximum height. There’s a point where it just stops going up and I hear pressure releasing in the jack
XrayMike
XrayMike
Alex
Chicago, IL
Deleted member 3063
Guest
check the oil level if you think there is more room to travel
FrankenRodz
sheldon
Massachusetts
2022 Base 2 - Door
I went too high on one and it never would hold again. Some don't have refill.
I put a 6x6 or 8x8 block on the jack to gain more lift. But no matter what you use, you should have Jack Stands in place as a safety.
Ford Bronco Need advice on floor jacks FB8A2184-F65C-4152-A285-764AFEF7F474
XrayMike
XrayMike
Alex
Chicago, IL
So I have enough height in the front for the jack, but won’t go high enough for the rear. Is it safe to jack up on either of these points?
Ford Bronco Need advice on floor jacks A9008A79-22F3-43E3-8332-71E8625B714F
Ford Bronco Need advice on floor jacks 17CBD8C6-3DFF-43E3-B450-E4C67F3AFEB5
1970AMCAMX
Robert
Titusville, FL
F150, AMC AMX, DF Goblin
Yes, pretty much anywhere on the frame or if your doing tires just jack up under the differential
XrayMike
XrayMike
Alex
Chicago, IL
I just need the tires off to tighten some spacers so I’m gonna lift under the differential
1970AMCAMX
Robert
Titusville, FL
Make sure to put jack stands underneath it
‘21OBX
90Bronco19
2022 bronco outer banks
Put it in 4wd and set the brake. Or at least chock the tires.
