My subwoofer delete solution
silver bullet
Alan
Chesapeake, VA
2023 Bronco Black Diamond
When I found a dummy speaker and amp attached to the subwoofer housing it made scatch my head. So I found a amp and sub to replace them, not perfect but they work.
Ford Bronco My subwoofer delete solution 20230321_170944
Ford Bronco My subwoofer delete solution 20230321_170949
Ford Bronco My subwoofer delete solution 20230321_181401
Ford Bronco My subwoofer delete solution 20230321_181415
Robs
New hampshire
2023 Black Diamond
Wiring details please!
silver bullet
Alan
Chesapeake, VA
I used the connector to the dummy amp for the power and ground. Ran inputs from the two rear speakers.​
greatlakes
Grand Rapids
67 Buick Special
That's hilarious Ford gives the enclosure, just not the subwoofer!
You may have better results tapping into the front speakers. The frequency response (bass) on the rear speakers is severely neutered.
silver bullet
Alan
Chesapeake, VA
I was going to try the forscan trick first
Changed ACM 727-01-01 to add full range to rear speakers
Changed ACM 727-01-02 to remove bass filtering by EQ to rear speakers
Then BANG..it was a little amazing
da_jokker
Jeep Wrangler JKUR
Huh?....so ford is installing the housing but leaving all the electronics out?
Ducati1098
Yes. They install a non-operational amp and sub which appear identical to a working set.
Ford Bronco My subwoofer delete solution 2DBFE315-6DC5-4842-A641-C5E8407ADE2F
da_jokker
Jeep Wrangler JKUR
That is hilarious. I had heard they deleted that subwoofer after they said they were adding it for 2023, but I thought delete men they deleted it.. not that they were actually spending the resources to install empty shells.
Mind blown!
Wish I could get my hands on one of those cheap..would love to add it to 2022 model (but working of course)
Sandbergo
Jelani & Dave
Orlando
Rogue
What gauge wiring is the power and ground from the factory plug? Should be interesting.
Ducati1098
12 gauge coming out of the battery junction box going to the amp, then it is spliced into 2- 18 gauge circuits right before it goes into the amp.
Then it has 2- 18 gauge ground circuits going into the amp also.
