My Outer Banks Bronco build
Area51outerbanks
Area51outerbanks
Livonia, Michigan
2021 Bronco outerbanks 4dr area51
Then we went to discount tire and my son had the wheels and tires ready.
35 x 12.5 x 18 bfgoodrich ko2's on black rhino shredder Wheels 18 x 9.5 with +12mm offset.
What a change, doesn't even look the same. We are super happy the way it turned 6.
Ford Bronco My Outer Banks Bronco build IMG_20210709_162711537
Ford Bronco My Outer Banks Bronco build IMG_20210709_162720188_HDR
Ford Bronco My Outer Banks Bronco build IMG_20210709_162726525_HDR
Ford Bronco My Outer Banks Bronco build IMG_20210709_162734352_HDR
Ford Bronco My Outer Banks Bronco build IMG_20210709_162747619_HDR
Ford Bronco My Outer Banks Bronco build IMG_20210709_162755445_HDR
Ford Bronco My Outer Banks Bronco build IMG_20210709_215631597
Ford Bronco My Outer Banks Bronco build IMG_20210709_215637451
doink
Atlanta
GLE 350. Bronco OBX
hows the rub (if any)?
RLW
Robert
Chattanooga, TN
2000 Lexus GS 300, 2022 Badlands, 2022 Honda Odyss
Looks incredible.
Hope that spacer lift holds up for your needs. Can’t wait to hear more about it.
Good looking ride. Very jealous I don’t have mine yet!
AKBronc49
Russ
Anchorage, Alaska
Looks great! Makes me want a set of standard painted obx flares for my sasquatch.
Mjtermini
2022 2DR Badlands
was contacted on facebook from redline tuning, they needed a bronco to test out the hood strut kit they made.
Of coarse I said yes
first mode was removing the front crash bars
2nd is hyd hood shocks/struts
[/Q
Discount Tire
Arizona, USA
discountti.re
All Things FORD
Discount Tire is the best - great service and prices. Never been disappointed.
Thank you for the kind words! We appreciate the continued support.
Shoot us a PM if you ever need anything, we'll make sure you're taken care of.
Area51outerbanks
Area51outerbanks
Livonia, Michigan
Did some trails today.
Tested all the different goat modes.
Love mud n ruts because it allows the front camera with tire view. It's amazing.
Trail turn assist is great, unbelievable how tight a turn it will do.
Ford Bronco My Outer Banks Bronco build IMG_20210713_183836046_HDR
Ford Bronco My Outer Banks Bronco build IMG_20210713_180838871
jaruss01
Love it. I like the clean look of OBX with painted flares with lift/tires/poke. That was my initial build (OBX AMB), but went to sasquatch after the mod top was dropped, to tie in the MIC top with sas unpainted flares. But if I was going soft top, i probably would have stuck with the initial build.
Couple questions -
Did you keep the crash bars in place?
Did you order with the auto 4wd and lower gearing?
What's the hit on MPG?
How dirty do the sides of the truck get with that amount of poke?
Area51outerbanks
Area51outerbanks
Livonia, Michigan
Couple questions -
Did you keep the crash bars in place? No I removed them
Did you order with the auto 4wd and lower gearing? I went manual 4wd but did order rear locker with 4.27 gears.
How dirty do the sides of the truck get with that amount of poke? It gets the sides a little but most is not from the poke but the flare doesn't go low enough.
