my 12 inch screen is possessed.
mustanggarage
chad
Iowa
2018 F150, 65 mustang, 71 bronco
anybody else seen this happen?
I read that I need to turn off contact synch. I did that and it stopped. now it seems to be working fine. hopefully this will help someone else.
AceGoliath
Charles
IL
21 Bronco OBX SAS , 22 Maverick XLT, 10 Fusion SE
Wouldn't hurt to do a soft reset. You don't lose any of your settings and everything is back up and running in about a minute.
When the vehicle ignition is on Press and Hold the Radio Power Button/Volume Dial and the Seek button (>>) at the same time for about 5-10 seconds until the screen goes black and the Ford symbol flashes on the screen and it resets.
mustanggarage
mustanggarage
chad
Iowa
thanks I read that works for a lot of problems, but I tried that with no improvement, If I shut the vehicle off or did a soft reset, it would allow the touch control to resume for a while, but the random schizophrenic jumping around of the screens would start right back and pretty soon it would lock out again. but turning off contact synch seems to have stopped it.
da_jokker
Jeep Wrangler JKUR
So it only does this when you have your phone connected?
Look like it was acting more like when you want to switch the small screen with the bigger section (as If the right side of your touch screen was registering a hit)
mustanggarage
mustanggarage
chad
Iowa
that was what I thought at first too, I thought maybe there was some fuzz or something on the screen and the heater fan was moving it causing it to freak out. I'll admit I don't know how the technology for the touch screen works, but I cleaned the screen, turned off the fan, waved my hands close to it to make sure it wasn't motion near the screen causing it. none of it made a difference. to be honest I didn't try it without the phone connected. but once I turned off the contact synch it stopped, and I have driven it a couple times since and it is working perfect so far. so I think it has to do with that. do you have an iphone, or android. I have an iphone 13 pro max,
da_jokker
Jeep Wrangler JKUR
Well there's your problem ... Lol ... J/k ... I'm an Android guy.. Don't really like Apple products.
Ironically, when I paired my phone and it was starting to ask for permissions, the one thing I don't allow it to do is connect my contacts... So maybe someone else can help you out there.
Tip... If you have a text message from a person you're trying to call, you can use the text message to actually dial them. Kind of a workaround if you don't allow it to know your contacts.
Docindahouze
Doc
Cumming, GA
Ford Bronco
It’s Christine! She’s back. 😱
Ford Bronco my 12 inch screen is possessed. 63EEBAB9-8136-4DE3-93B3-62A487892A34
mustanggarage
mustanggarage
chad
Iowa
I’m sure that would work however, since the Apple CarPlay works just fine the contacts in my phone are already there so I don’t need to download them anyway.
Tricky Dick
Dick
PNW
www.TD-Distributing.com
Mine did that when I drove doorless in heavy rain and it got soaked. Some sort of a short I'd presume.
mustanggarage
mustanggarage
chad
Iowa
Well I spoke too soon I guess. It started doing it again today smh. I guess I’m going to have to contact the dealer
mustanggarage
mustanggarage
chad
Iowa
well, since my last issue, I got my new RSE stepslider steps. I put them on the 30th of december about 2 weeks after I took delivery. to install them I had to run the power and ground wires directly to the battery. and I had to bolt the on off rocker to a bolt near the fuse block under the steering wheel. I made sure all my connections were secure. the ground wire on the battery was not super tight, but it wasn't loose really, and I pressed on all the fuses under the steering wheel also. I don't know what was going on, but since the installation I have had not one glitch. the full screen apple carplay download happened thursday with no incident, and I have taken the bronco on several long drives and over some relatively rough roads and so far it has been over 2 weeks without a glitch. I am guessing that battery ground was just not quite tight enough. either way I am optimistic. I guess I will cancel my appointment in the morning. I am loving this thing. it is a blast to drive. and I am so impressed with how the suspension handles the rough roads.
Ford Bronco my 12 inch screen is possessed. IMG_1575
