Multiple Trouble codes- Sub Freezing temps 2021 BD 2.7
Rus-T
Rusty
FL
Ford Bronco Black Diamond
Remote started my 21 BD this morning. No issues with start up, but when I got in and hit the engine start button, a bunch of notifications came up. Service engine soon, Pre collision assist not available, and driver mode not available which is the ability to change G.O.A.T Modes. I have a Ford performance tune so I hooked up the Pro Cal and read the following trouble codes.
There are 5:
P0236-Turbocharger Boost sensor A Circuit Range/ Performance
P050A -Cold Start Idle Air Control System Performance
U0284- Lost Communication with Active Grille Air Shutter Module A
U0285- Lost Communication with Active Grille Air Shutter Module B
U1012- Invalid Internal Control Module Monitoring Data Received from Anti-Lock Brake System (ABS) C
I never had these codes before, and I drove it 5 hours yesterday and it was just fine. I am in Illinois, and the temps last night were -12. When I started it this morning it was -10.
I drove it down the street about a mile and it runs like garbage. Loss of power, and exhaust sputtering.
Just wondering if anyone else has had this happen to them in extreme cold over the last few days. I don't know if it will be fine once it warms up above freezing, or this is a dealer visit.
Ford Bronco Multiple Trouble codes- Sub Freezing temps 2021 BD 2.7 IMG_0728
Ford Bronco Multiple Trouble codes- Sub Freezing temps 2021 BD 2.7 IMG_0729
Ford Bronco Multiple Trouble codes- Sub Freezing temps 2021 BD 2.7 IMG_0730
Ford Bronco Multiple Trouble codes- Sub Freezing temps 2021 BD 2.7 IMG_0731
Ford Bronco Multiple Trouble codes- Sub Freezing temps 2021 BD 2.7 IMG_0732
Fishwrinkle
12 GC overland 5.7, 18 GC srt 6.4
man that's a total bummer and wish you the best. i too have been battling ford gremlins for a solid year now but not these codes. it was 5 in MI at 5am this morning when i left for work but with wind chill it was -15. i park outside and had to jump my bronco as the battery voltage was at 5.7!!! i just bought a new battery while i fight with the the dealer it's a bad battery.
it's not hard to see that it's the battery as it will never get to 100% charge on a trickle charger and after that it reads 12.4 which is only 50% charged according to all the agm charts i've found. 100% is 12.8-13+
Boreal
Colby
MB
www.cspencephoto.com
2022 Badlands 2DR
I am not a tech, but for a rash of issues suddenly during a cold morning suggests either a bad section of wiring harness/loose connector/bad pin fit or some rodents got into the engine bay to stay warm and found a snack. Sometimes low battery voltage does wonky things too...
Of course, the codes might be all independent of each other... best of luck with the fix
FWIW: Im driving a 2.3L BL and its -32ºC/F this week, and Ive never come across any of these codes (or any other local owners)
Ducati1098
Pop your hood and take a look at the sensor right in front of the throttle body and any wiring in the surrounding area. Maybe there is something obvious. If not, I’d recommend just bringing it to your dealer so they can properly diagnose the issue.
Ford Bronco Multiple Trouble codes- Sub Freezing temps 2021 BD 2.7 IMG_2662
akturbo
Seattle Eastside
What sensor is that? MAF?
Rus-T
Rus-T
Rusty
FL
I'm going to take it to a heated garage this morning and let it sit for a few hours and see if starting up later today will change anything. I'll check out the sensor on the throttle body as well. Thanks for the input. I'll post later today on what I find. I appreciate the help all.
Rus-T
Rus-T
Rusty
FL
Heated garage did nothing. I checked the sensor and surrounding area... Nothing obvious. Made an appointment with Ford, but of course, the soonest available is 2 weeks out. This sucks!
da_jokker
Jeep Wrangler JKUR
Seems like multiple posts now that its getting pretty cold. One person was having issues putting it in 4x4 mode while another won't even start.
I wonder if extreme cold, like extreme heat, just tends to exaggerate underlying problems and make them show up?
Maybe a warm garage and a reset would wake it up?
Rus-T
Rus-T
Rusty
FL
I agree. This is the first winter for her. I’ve lived in South Florida since I picked her up in July ‘21. No issues at all there. The crazy thing is I drove 5 hours the day before this happened and no issues. It sat outside over night and the next morning, this started. Going to dig in to some troubleshooting today.
cbrenthus
Western PA
'22 BadSquatch, '02 T/A
I had a boat with a Merc 2 stroke DFI that needed a 1000CCA battery. The word was that it needed the current on startup to power the electronics. I found that if I didn't keep the battery on a tender when not in use, it wouldn't run right.
Where I'm going with this is that with the sensitive electronics in these vehicles, I wonder if what we are seeing is caused by not having enough current on startup? Very possible with a year or 2 old battery in cold temps ;)
Rus-T
Rus-T
Rusty
FL
So yesterday I took the turbo boost sensor off and cleaned it. It didn't look like there was any buildup on it, but I tried anyway. After cleaning it, and starting it up, boom, it was fixed, for a few test drives anyway.
Drove around for about 5 miles.Ran great. Parked it. Had to run to the store a few hours later... fine. The third time later in the day, the codes came back and it ran like garbage again. I think it is the sensor, and it is possibly going bad? If that's a thing. I ordered a new one to see if it completely fixes it. The only code showing up now is the P0236 (turbo boost sensor A circuit)
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
There are 5:
Hi there! Would you send us a private message with your VIN and dealership name and location? I’d like to look into this concern on my end.  
Rus-T
Rus-T
Rusty
FL
*** Update***
After 12 days in the dealership, the diagnosis and fix was replacing the turboboost sensor (MAF) as we all thought. Literally a 2 min. fix, which I was going to buy and do myself, but the sensor was $120, and I still would have waited 7 days to get it so with it covered under warranty I just let the dealership keep it till they fixed it. I’m just glad it was covered, and she is running as good as ever now.
Just wanted to update this thread in case someone else runs into this issue.
Thank you all for the input on this.
Ford Bronco Multiple Trouble codes- Sub Freezing temps 2021 BD 2.7 IMG_1075
Ford Bronco Multiple Trouble codes- Sub Freezing temps 2021 BD 2.7 IMG_1076
