2022 Black Diamond Intermittent Trouble Codes
Alaska
Ford Bronco
I have a 2022 Bronco that I bought from a private owner that started having multiple intermittent trouble codes (mostly powertrain malfunctions , service engine soon , pre-collision not available ) out of the blue starting at around 5200 miles on it and I now have only 7300 on it . I've had it to the dealer on 3 separate occasions now and they haven't been able to pinpoint the cause yet and I'm ready to take it in again for the 4th time . Has anyone else seen or heard of this issue in other rigs ?
dcaero
Bronco OBX SAS
Could be worth getting yourself Forscan that way you can check the actual errors while they are active. May help your dealer narrow in to whatever is going on.
Alaska
Ford Bronco
The third time I took it to the dealer the codes were active . Dealer thought they found the problem but obviously not . I'm looking into Forscan now , thanks .
