Mud Flaps -- install all 4 or just the fronts?
Bocapilot
Don
Okay I’ve decided to get mud flaps to help with paint protection and friggin dirt splatter. Anyone go with just front flaps? I’ve got a Non Sqch Badlands. Gonna go with rokblokz Just wanna see pics or advice on all 4 or just front.
pictures plz
Thanks
mintypickleman
A
2008 f150
JediMcMuffin
Tommy
2026 F-150 Tremor 401A
I use the Rokblokz (yes, they're overpriced). I run all four for daily driving and long highway hauls. Remove the rears prior to off-roading while airing down, and put them back on while airing up. I don't do enough extreme rock-crawling to also pull the fronts.
AKBronc49
Russ
Anchorage, Alaska
I've only had fronts since I took delivery in November. I have a rear set but just haven't installed them yet.
Ford Bronco Mud Flaps -- install all 4 or just the fronts? 20220611_172404
Biff
Southern WV
2016 Honda CR-V AWD SE
I have Rokblokz on the front only, and combined with the OEM tube steps, no more rocks or mud splatter on the doors. I will most likely eventually get rears as well since the rear plastic bumper has a gap that allows splatter through. Plus, as badly as we are all concerned about windshield chips from rocks, I want to pay it forward.
Ford Bronco Mud Flaps -- install all 4 or just the fronts? EADDA7E8-AD06-46C1-BCAF-E5B03061B522
Jroub21
Everglades
Bruno
Wahoo
‘24 Everglades, ‘17 Fusion, ‘21 Wrangler 4xe
Everglades
I’ve done just fronts on my Gladiator while waiting for my bronco. Just wanted something to get me by so the body doesn’t get too beat up w rocks. If I were keeping it long term I may have considered going all 4. But still totally content w j fronts.
Scott R Nelson
Meridian, ID
The rears will keep some mud out of the recesses in the bumper at the rear. Doesn't help at all in the front bumper area.
I just installed a set of WeatherTech flaps over the weekend. They're reasonably priced at $55 a pair. I still need to go drive through some mud to "test them out". ;)
Ford Bronco Mud Flaps -- install all 4 or just the fronts? QDyuKZe
Shane78
Shane
St. Louis
2D
I’ve always ran front. Back are kinda pointless, if you’re going over 30 mph any gravel that the rear spit is gonna spit well behind the bronco. Me and friend compared my Rekgen and his rokblokz, they are basically identical. And Rokblok is twice the cost.. minus the fact that they are quick release (which 99% of people are never gonna utilize), they are not worth it. Anywho, just my 20 cents. Here’s some pics to help.
Ford Bronco Mud Flaps -- install all 4 or just the fronts? AC6C028D-F89A-4364-9403-5907EF5A2518
Ford Bronco Mud Flaps -- install all 4 or just the fronts? EE16FE71-CB16-49DC-BEA0-4145B835BFB5
Ford Bronco Mud Flaps -- install all 4 or just the fronts? 84426E71-1B1A-4103-9A2B-1755173F2902
Ford Bronco Mud Flaps -- install all 4 or just the fronts? 383AB66B-480E-444C-949B-05932CD31212
Ford Bronco Mud Flaps -- install all 4 or just the fronts? F35A301D-0AC6-41FB-8EFB-906A10F9632D
Naters317
Nate
WI
22 Bronco Base Sasquatch
Are these the regular length flaps or XL?
Bocapilot
Bocapilot
Don
Thanks for the replies and pictures. Ordered the Rokbokz all the way around. I’ll post a picture when they arrive. Website says may be slow delivery due to demand. Guess a few Broncs are ordering
KIILew
Prosser, WA
2016 Silverado 2500 Duramax, 2020 F-150 3.5
I hope you like the RokBlokz! I just installed mine this past weekend...we'll see how they hold up. I initially installed all four flaps to the letter of the instructions, but the next day, I decided to experiment with the front ones, swapping the brackets from side to side. Doing this actually seemed to improve the stability of the flaps for me, as well as reducing the "buzz factor" where the upper edge of the flap rests against the fender flare. Plus, this swap repositioned the front flaps more perpendicular or "square" to the body surface of the vehicle than they were initially. I have the smaller tires of the standard Badlands, and even with the brackets reversed the whole flap assembly is at least flush with the crash bars, so I have no interference issues.
Ford Bronco Mud Flaps -- install all 4 or just the fronts? 20220807_130702
Ford Bronco Mud Flaps -- install all 4 or just the fronts? 20220807_130618
BottleShark
TJ
East Texas
Nautilus, Samurai, 12v Dodge, Fiero, Karma Ghia
I love the way they look, I'm just to cheap. $20 Amazon ones for me. They look good and work just fine.
Murraydog11
Rick
2021 2Dr Outer Banks, Jeep Cherokee
I'm rolling with just fronts.
Ford Bronco Mud Flaps -- install all 4 or just the fronts? 20220804_183949
