MPG
KreeHBronco
Kevin
Bay area California
2026 Badland 4-dr Manual
2026 4-dr non-SAS Badlands w/2.3L manual. Recently drove from San Jose to LA on the I5 freeway (~375 miles one way). Speed was between 60 and 85, depending on traffic (semi-truck passing semi-truck at speed 1mph faster). Really loved using my ACC. MPG was about 18.5mpg down/back. Around town I am getting about 17-18mpg. I still only have 2400 miles on it, so hopefully it will improve slightly. Speed and wind do play a major factor in my mpg. I am pretty sure I could get over 20mpg if I drove below 70mph.
Desmolicious
SoCal
2025 Bronco HE, MX5
Anyone else get less MPG on the highway vs in town driving?
2025 Big Bend - in town driving average 21.9 MPG, but on the highway it drops to 20 MPG.
Normally, in every other vehichle I've owned the MPG increases on the highway.
Thanks!
The only way I get 21.9 mpg around town is if I average 60mph in a school zone.
CalvinT
Calvin
Phoenix, AZ
I did a 300 mile roadtrip last weekend and was turning almost 25MPG on the computer
Have you calibrated your computer? The computer mileage isn't accurate unless it's been calibrated, mine read 6% high.
KillerPenz
North East
I definitely get worse on the highway than around town, but I also figured out what is a major issue with highway driving, it's the left lane dicks! I can easily average over 18 MPG on the highway doing between 80 & 85 as long as no one is in front of me. But as soon as you get the idiots that don't know how to keep right except to pass you are screwed. It's the constant slow down, speed up, slow down again, speed back up. That's what kills my mileage.
Eldowerks
Minnesota
Bronco ‘24
I did a 300 mile roadtrip last weekend and was turning almost 25MPG on the computer (lower IRL, most likely).
Yeah re computed MPG, it’s always too optimistic.
I do the miles per gallon math right after a fill up at the gas pump and the real MPG with my 2.7 AT is always at least a half a mile per gallon lower than computed on the infotainment screen.
AZ_Liberty
2007 Expedition
Thanks!
Yes.
23.5 in town. About 21 on the freeway. Bronco is a brick.
Only vehicle I have ever owned that gets worse MPG on the Freeway.
Also, unless you are going downhill, you get better mpg in 5th than 6th since 6 causes the engine to lug.
adamruiz2001
SoCal
Ford SVT Lightning
My MPG (Badlands, Procal, 35’s) is running 18.7 on the long average. The most impactful thing for me is speed on the highway. Over 70 it drops significantly. Like from 20-21 to 16-17.
How in the world are you guys getting decent MPGs? I have BFG 35s, I average 14.5-15 in town, easy on the gas pedal, and hwy (@75-80MPH) I might see 16, I do get better if going 65, I can see 18 MPGs at that speed. I did notice a huge drop in mileage when I went from the GY tires to these BFGs, so I hope when I change tires again, and possibly wheels, I might see my MPGs bump back up with the lower rolling weight, for now, it is what it is.
Big Red Rocket of Love
2024 Ford Bronco
24.2 mpg combined. 2.3L
~Steve
chris harley
chris
Minnesota
2025 Bronco
If I went 75-80 on the highway my MPG would drop like crazy. My tires are 315/70 KO2’s at 34 cold.
Vynull
Jake
Goshen, NY
2026 Bronco Heritage 4-Door 7MT, 2001 Saab 9-5 Aero Sportcombi
Checking in here. I am constantly amazed at the mileage I am getting. 4dr heritage 7mt with 1800 mi on the odometer. Averaging 22 combined. More around town than highway recently. I do coast down big hills and try to shift out of 1st/2nd/3rd by 1900-2200 rpm, but aside from that I drive pretty normally. Highway is always kept between 65 and 72.
JL8jeff
Ewing, NJ
80 mph is too high for the Bronco, you need to keep it under 75 (70 or less if hoping for ok mpg). In the 65-68 range I can get 20 mpg with my base 2 dr 2.7 Sas lifted with 37's but I also have some mods that help (exhaust, intercooler, charge pipes, FPP tune, CVF intake, GPE TB). In the 58-62 range I can get 22 mpg with no stop traffic. I keep track of all gas and miles so it's a real calculation, the computer is at least .5 to 1 mpg overly optimistic.
CalvinT
Calvin
Phoenix, AZ
