Mouse chewed through front wheel speed sensor wires
RSNovi
MI
2022 Bronco OBX
Hi All,
Thank you to all who have helped me find the appropriate connectors and wiring to investigate this fault. As expected, all the lights on the dash for ABS, stability control, driving modes, etc., are all faulting. I made progress, but still haven't fully solved this.
I used Forscan to discover an open circuit on the front right wheel speed sensor. I initially just replaced the sensor, but damaged the old one during removal. With the new sensor, the issue persists.
This past weekend, with more information, I examined the wiring and found that the harness behind the inner fender had been chewed by mice. The damage occurred after intermediate connector C1137 on the harness that feeds the wheel speed sensor and other components, such as the front diff lock. The damaged wires were a twisted pair, with the low-side sensor wire completely severed. The power wire was damaged but remained intact.
I repaired the wires using 20-gauge wire, replicating the twist as best as I could. I soldered and shrink-wrapped the wires. I consider myself fairly capable with this, and believe I made a solid repair. I measured 0.6 ohms of resistance from the speed sensor connector to the ABS module connector pin.
Even after this repair, I am still getting a code for insufficient wheel speed sensor transitions. Back to the drawing board, I measured the voltage across the speed sensor. With the engine off and key on, it measures about 11.3V, indicating that the ABS module is providing power to the sensor. However, when I spin the tire, I don't see any voltage fluctuation. I suspect the new sensor I installed may have been damaged because I hadn't fully corrected the wiring yet. That's my hope, at least.
There was a large mouse nest in the inner fender well, near the bottom of the door. I noticed missing pieces on the pad around the battery when I removed it and suspected a mouse, and found it all in this nest.
BroncoDave24
East Tennessee
'61 Falcon, '87 F150 XLT Lariat 5.0, '01 F350 7.3L, '24 WildTrak
They love the Soy based wiring insulation!
Headsong
BEHIND the fender? How am I supposed to spray that.........these freakin' engineers......
Quatermain
Idaho
2025 Bronco
I always keep a little D-Con in a plastic cap or other suitable container somewhere in the engine bay. No problems in the past 20 years. Works for squirrel sand chipmunks too.
I have yet to find anything that continues to work - just about everything I've tried the damn pests just get used to it and move in anyway.
The mint spray stuff worked for a couple of months. Now it just makes my Bronco smell like Christmas and garlic. I've done the Decon route - my wife hates it, she's convinced it will kill her cats, but that hasn't really worked anyway.
Leaving the hood up ... well, that has problems of it's own. Like pine cones and needles in the engine bay. Have not tried one of the ultrasonic things - my Inlaws had them in the RV and didn't seem to do much there though.
So tired of acorns rattling around inside the hood and all the air filters. No idea how they get in the cabin air filter, but they do.
RSNovi
MI
2022 Bronco OBX
I was able to get this working. Turns out I had received a left wheel speed sensor and I was working on the right side.
With the correct sensor in, everything started working. My wire repair was sufficient.
