Most important skid plate besides front
kevin.gt
Kevin
Canton, GA
You can see some dirt on my cross member support bracket near my fuel tank. That was from one trail in NE Georgia that was a bit rutted. Kinda wish I would have held out for the LoD transmission skid instead of the Asfir skid just to cover those up and smooth it out. Hope I don’t get caught up on them.
Badassbronco
Georgia
I just bought the OEM transfer case skid. I think I’ll add the gas tank skid in the near future as well
Thanks all for your help
Go Devils
Reed
fuel tank. it's plastic, exposed, and huge.
The OEM transfer case skid is about $50 shipped from Ruxer. Seems like a no brainer.
Some people on the forum are fabricating their own transmission skid from 1/4" aluminum, but the metal isn't that cheap, so I just bought mine from Asfir when I ordered the fuel tank skid.
You mentioned Ruxer has the T case skid plate for $50? Do you have the link by chance? I couldn’t find it. Thanks.
kevin.gt
Kevin
Canton, GA
You’ll need to create an account, then message @flip and he’ll add you to the b6g discount. Then when you shop AND you are logged in, you’ll see cheaper prices. One thing to note: i need to be logged in when i add to cart as the price does not drop in cart after logging in. For instance, the transfer case skid is $36 plus ship. Note, you will need some hardware too.
Skid:
https://www.ruxerparts.com/oem-parts/ford-plate-mb3z7e063a
Bolt (4 needed):
https://www.ruxerparts.com/oem-parts/ford-bolt-w717376s439b
Clip nut (2 needed):
https://www.ruxerparts.com/oem-parts/ford-bracket-nut-w717461s439
Cwill79
Kentucky
Tundra
How did this install go? Pretty straight forward? I just ordered as well.
Thanks
dejones64
Dan
MN
Bronco 2-dr Black Diamond
Gas tank, but catalytic comes to mind.
M&M Beer
Marty
Ford Edge-F-150 Supercrew
My skid plates came plastic I ordered a MOD bumper took it back to the dealership and they did a little mis-build form and now they are ordering a new set this time steel. Make sure to check the bash plates this happened on several models with the MOD bumper.
ChompSticks
ChompSticks
Cumming, GA
'02 E55 wagon, '98 Suzuki X-90, '96 Town Car
Rear shock skids. I nailed both sides pretty good that it almost punctured the shock itself.
Ford Bronco Most important skid plate besides front 1674673886036
cburke996
Santa Clara CA
'67 Firebird, E39 M5, Lotus Elise
The transmission cross member braces are pretty vulnerable, have bent edges that seem to catch everything. Mine quickly got hit. So I covered them up with the JCR trans skid, which also necessitated the front/engine skid to go with it.
