Modular Front Bumper Option....sort of
MFP2241
WV
2 Door Antimatter Blue BaseSquatch
Front hooks which are heavy but have some pitting (presumably cast) and not identical to the stock ones.
The cast quality and structural integrity of the hooks, in an actual recovery situation, would be my only concern with this bumper.
I'm fairly certain Ford appropriately tested the strength of thier hooks, unsure if these received the same scrutiny.
Sandbergo
Jelani & Dave
Orlando
Rogue
Wonder if you could buy the Ford hooks and use them instead.
Miker002
Boerne Tx
Truck
If you find the hooks please let me know I have been looking for the part number but I end up with something else. But I also must admit it was a single attempt lol
TheShark
Pretty much my exact experience putting the ebay mod bumper on. I did learn something though, I had two screws left over after the install and now I know what they are for, to hold the tow hooks in place. Oh well, did really have a problem installing the bumper without them and it probably made it easier when I swapped the tow hooks for a pair of orange Ford Performance hooks.
bronco346
How's every one's bumpers holding up?
Darkjeep
Dan
Hastings, MN
F150, Bronco
Besides the scratch from the shipping mine is doing well. I did get the Ford recovery hoop because the shackles I bought wouldn't fit past the poor casting line in the middle of the Chinese one. It looks good and I am happy with the price and install was easy.
TheShark
Mine is holding up just fine, I did replace the front hooks with orange ones from Ford Performance.
Ford Bronco Modular Front Bumper Option....sort of B715A4A9-69AE-4F81-B194-5706B13FDA16_1_105_c
The photo also highlights my $165 Chinese knockoff Raptor grille.
BostonSasquatch
Randy
Boston
Bronco Lux Badlands with hardtop and Sasquatch
Two to my dealership was $1,281.29, of that $562.10 was shipping, $600.60 was the two bumpers, the rest is probably some made up tax.
So you got two. Can you report on the quality of these things? And the fit? Do you have to provide extra, or different, fittings, nuts & bolts?
flip
Phil
IN
www.ruxerparts.com
Fords
Everything is pretty much there to install it but you will need to swap over your existing harness and park aid sensors. As far as quality, I got a set of the Mabett knock-off raptor style fogs and they didn't fit worth a crap. I don't know if that's because the end cap or stamping is that far out of spec, fog light assemblies or combination of both.
The weight of the bumper, back mounting brackets seem to be similar to OEM but all of the button head bolts that hold the caps on as well as for mounting a bull bar are standard over seas quality. They do have thin plastic washers under each bolt presumably to avoid damaging the bumper coating/paint. Don't know if that's due to the lower quality of the finish or just an added layer of protection but the OE "Bronco" bolts don't have that.
Bumper I'm going to put on mine has some imperfections on one of the caps that appears to have been done during the manufacturing process and was not corrected prior to paint. For the cost, this is to be expected. It does come with OE style front tow hook brackets but the finish is different that factory and I would assume it probably wasn't tested to failure like the OE. Would I spend the $$ to put OE hooks on? Probably not unless I was going to do a ton of off-roading, had a winch and relied on them as the main hook off/yank/pull point. The OE could still fail and all you are gaining is a marginal amount of insurance assuming the OE quality is superior.
I think these would be a good option for those wanting an OE style MOD bumper with no plans to go aftermarket. Quality is in line with the cost and if you were going to go banging around on a trail and it got damaged, it's less of loss $$ wise compared to the OE MOD part costs. I don't have spare OE end caps laying around or I would throw them on just to see how or if they fit. The caps are about 1/3 of the cost of the whole OE setup and generally the most trail damaged part of the front bumper.
JR23
J
Mass
23’ Bronco
Did the install on an eBay bumper today. Everything lined up nice and quality seems decent.
went with a mabett bar, mishimoto plate mount, ford recovery hooks, asfir aluminum skid, and lights on the factory fog harness(not working yet).
Ford Bronco Modular Front Bumper Option....sort of IMG_0422
Brandonj83
Brandon
F150 Raptor
Looks like there are two versions of the aftermarket mod bumper. The first picture is one from EBay that cost 325. The end caps on these are not like the factory ones as in the whole piece comes off instead of leaving the top bar all the way across. I ordered the one in the second pic off Amazon which looks like the factory one.
Ford Bronco Modular Front Bumper Option....sort of IMG_0168
Ford Bronco Modular Front Bumper Option....sort of IMG_0169
j_anderson
Jason
Fort Wayne, IN
www.instagram.com
full review when you get it installed please!
