Mobridge Amp Install Questions
monkeyballs612
Pennsylvania
Toyota Rav4 Adventure Edition
I bought a gearshade box and will be buying the Mobridge amp/dsp (once there is a discount 😉). Since I plan on mounting everything behind the factory panel how do I continue to adjust the dsp settings? The logical perfect thing would be some kind of USB adapter that mounts and plugs in to the amp? Does anyone on here have a dsp hidden and a solution to not take panels apart for adjustments?
WillinMA
Will
Groton, MA
2021 Wildtrak, 2023 Urban Defender, 2020 Lambo Huracan Spyder
There is a usb cable you attach to the amp and then have the other end hanging out by the rollbar - then anytime you want you can hookup to a laptop and open their app to change whatever you want ( including firmware releases)
mpeugeot
It's easy enough to just tuck the USB cable under the carpet when you don't need it. Sure, you could put an access port in the panel if you want to.
