mObridge dsp/amp ***DSP configuring***
Lowellbarton
Lowell
Dallas, Tx
2022 Bronco
Anyone have a similar setup as mine with a good map file?
In all my excitement, I've overwritten the stock file.
what I'm using:
3 - 4" KSC40's in dash
2 - 6.5 KSC650's in the kick panels
2 - 6.75 KSC6704's in the rear pods
1 - CompR 8" in stock sub enclosure
All Kicker brand
ssqch
Bruce
Richmond, VA
'22 Bronco
Has anyone got Fraser's file, the 4 presets, that comes with the amp for his setup? Somehow mine got erased when I did the firmware update a few days ago. Thanks!
jabrax
Willow Grove, Pa
2023 Badlands Sasquatch
I think Fraser's file is custom starting file for your setup. If you are in a crunch you can get the base bronco file from the support tab at the bottom of the product page. It doesn't sound as good, but it will get it running again. I had mishap earlier and my file wiped.
ssqch
Bruce
Richmond, VA
'22 Bronco
It's a .rax file. How do you open it on iOS?
jabrax
Willow Grove, Pa
Open it with the Mobridge app. I created a file called Mobridge Tunes and leave my versions there.
<file> <open new tune>
Whenever I make changes I "save as" a new name to also keep the original
If you want to see it while not connected to the car - select "enable offline editing" near center of the screen
Chritaka
DFW, Texas
'23 WildTrak; '06 Whippl'd Mustang (sold4upgrades)
I'm running all Hertz Cento line... CX100 4" in dash corners, CX165 in rear Mabett pods, PRV 4" neodymium mid in center channel, Hertz 165L in the kicks. I'll be doing the JL Audio stealthbox as well. I was messaging with Mobridge on IG and he said they have a tune already for this setup.
Is there any way to flash the amp prior to install? Can Fraser do it before shipping? I asked the same via IG and will update when I get a response.
BigJ2
Jimmy
East Coast!
2023 Wildtrak
Good questions. Fraser has been pretty responsive. I’m getting it dialed in, but it’s not to its full potential and I can easily hear it. At any rate, I may have to take it into the pros with a mic and such.
jabrax
Willow Grove, Pa
The tune will come loaded on the amp
Chritaka
DFW, Texas
Only if you email them or send a msg with your setup. I sent Fraser a msg in IG and also replied to the order email with my config. He said he’d preloaded the tune for my setup. Just need to get the time to install everything!
Hemisfear
Bronco Bob
Lotusland
2014 Focus ST
I have a similar set up I'm currently working on installing, 4xCX100, C165L & JL8w1v2 in the factory enclosure, what can you tell me about the PRV 4" mid/centre channel and how does it interact with the CX100's you installed?
Chritaka
DFW, Texas
It’s ok, fills the need. It seems a little harsh at times. I’ll replace with Hertz or Morel at some point I think, so they’re all matched.
Hemisfear
Bronco Bob
Lotusland
2014 Focus ST
Thank you...l
I think I may wait to do something with the centre channel once I have everything up and running (I have the speakers installed, but still runninmg on the B&O). If I decide the 4" in the rear won't work for my taste, I will use one of the CX100's as a centre channel, tuning out the tweeter and go with the larger rear pods, I'm just concerned that the boxes look a bit tiny for a 6-1/2" speaker, sort of defeats the purpose of going larger!
Chritaka
DFW, Texas
Thank you...l
You're welcome and sounds good. Note that I had a noticeable difference with upgrading to 6.5" with Mabett rear pods on my B&O, esp. with the mid bass, but the 4" may fill enough for you once you have it all in place. I covered the inside of the pods with Kilmat and added poly also.
I was also looking here at some of their single mid bass woofer options for the center, particularly their FaitalPro 4FE32 and the Morel 424D Shallow 4".
baskethead
Greg
Florida Panhandle
24 1500 at4x, 23 z06, 89 waggy
Ive just finished installing everything and was wondering if anyone has a rax file with a similar setup to get started?
thx
Greg
AF GB15
AF GB60
AF GS 42 (center)
AF GS62 (rears)
JL stealthbox sub
