Mo' zone lighting and mo' cameras - forscan
Marshhunt
2018 RAM 2500
Mine shows all views front and both side cams. Can view in panorama, or 360 view
This is what I have available during normal driving. The only thing that changed is I can access it at any speed.
Ford Bronco Mo' zone lighting and mo' cameras - forscan 1651153572703
This is the view that I want. It is still only available when in Baja mode on my WT.
Ford Bronco Mo' zone lighting and mo' cameras - forscan 1651153621737
By far not my biggest problem but I park with my left fender right up against a upright freezer and having this view available without having to stop and shift modes would simplify that little daily aggravation.
j_anderson
Jason
Fort Wayne, IN
www.instagram.com
ah! I see, I have an OBX. I don't have Baja or Rock Crawl Mode. I had no idea there was another cam mode. I have the 3 to the left of the one your arrow is pointing to.
edit: maybe Forscan could add it to the other GOAT mode cam view options?
Marshhunt
2018 RAM 2500
I keep holding out hope for someone to find it in Forscan but they haven't to my knowledge.
j_anderson
Jason
Fort Wayne, IN
www.instagram.com
Now, I want that cam mode. I can see how it would be useful
‘21OBX
90Bronco19
2022 bronco outer banks
Any chance you can clue us into the access at any speed? I’ve tried multiple things but haven’t gotten it to work. I’d like to be able to tap the camera button just before parking or parallel oarki
Can you clue us in to what you changed to access at any speed I’ve tried a few things can can’t get it. I’d like to be able to tap the camera button before parking and parallel parking before I get under 5mph
Marshhunt
2018 RAM 2500
You would need to purchase and install either
https://www.4dtech.com/canopener-motion-unlock-for-sync-equipped-vehicles/
or
https://www.4dtech.com/canopener-motion-unlock-360-camera-unlock/
UtahBrandon
UtahBrandon
Brandon
www.puravidaoffroad.com
a number of classics and my 4dr Badlands
I was running some sand dunes in Utah with periodic rocky ledges and really wanted to use my wheel cameras in Sand mode. Surprised that my wheel cameras weren't available in Sand mode. Bummer. Still holding out hope that someone can crack this one.
j_anderson
Jason
Fort Wayne, IN
www.instagram.com
I have an OBX and the tire cam is available anytime I go to a 4wd GOAT mode.
Thanks for the heads-up. I'm going to try it out!
