Missing firewall grommet?
buzzcutt2
FL
I installed my Redline hood struts today and noticed this hole...this is the driver's side, I'm assuming a grommet is missing? Not sure it really matters, but 2022 2 door Wildtrak
Ford Bronco Missing firewall grommet? PXL_20230714_194346566~2
RagnarKon
Ford Bronco, Escape, Focus
Yeah there should be a rubber plug there.
On the 2.3L that hole in the firewall is occupied by brake system. 2.7L its just a rubber plug.
buzzcutt2
buzzcutt2
FL
@flip Any chance you can find a part number for me?
flip
Phil
IN
www.ruxerparts.com
Fords
I tried to find the thread where someone else asked the same question but can't find it. It's not in the catalogue under the plugs section. Have to go out and get the engineering number off of one in the shop.
buzzcutt2
buzzcutt2
FL
Thanks for checking...much appreciated any info you find.
buzzcutt2
buzzcutt2
FL
Much appreciated @flip ! (y)
Aman
Aman
Northern NJ
I thought it is for the clutch, not the brakes. 🤷‍♂️
Roger123
Roger
VA Beach, VA
Mine was missing too, I brought it in and they replaced it.
mike8675309
Minnesota
I believe that is incorrect. Instead that hole is filled by the parts for the clutch pedal and reservoir on manual transmission vehicles.
flip
Phil
IN
www.ruxerparts.com
Fords
All of the plugs and grommets have a section but no, they decide to put this in the powertrain category.:mad:
RagnarKon
I just went out and looked at it.
It is indeed for the clutch. My bad. The line is connected to the brake reservoir, so I just assumed it was for the brakes. The 2.3L has a vacuum brake boost while the 2.7L has an electronic brake boost so it all made sense in my head that they would be different. BUT, the once you look at it, it's pretty obvious the clutch shares its reservoir with the rest of the brake system.
