Mismatched tire rating
Rocki
New to the world of off road tires and different ratings. Bought my 22 BB four door in July, previous owner had put Falken AT3/W tires on it, 285/7017. The dealer I bought it from had replaced the front tires due to uneven wear from an alignment issue. I just noticed that the front and rear tires are the same size, but different ratings.
Front Tires
LT285/70R17 116/1130 Load range C
Ford Bronco Mismatched tire rating IMG_2668
Rear Tires and Spare:
P285/70R17 117T Standard Load
Ford Bronco Mismatched tire rating IMG_2667
Is this an issue? I wasn’t up to speed on the different load ratings etc when o bought it and missed the difference.
If it is an issue, which ones should I match?
Fordified1
Bob
Mid South Texas
I would probably just make sure to keep the matching pairs on the same axle. (Front or rear). But it would be curious to measure circumference of each with a flexible tape measure or use a string. They do need to have the same roll-out especially if you use 4A on the highway.
dgorsett
colorado
F250, Mustang, Explorer
I went to Falkens' website and discovered that while they are the same OD 32.8 the P tires are 50 # each the LTs 60#, so definitely keep them on the same axle, which messes up your rotation options. Oddly the P tire has a higher load carrying rating than the Lt. I might see if there was a way to swap out for the ones you prefer. I'm a big fan of LT tires for puncture resistance and sidewall strength.
28034306P285/70R17SL-117T7.5 - 9.58.532.811.36471350.5283351660-A-B
28037616LT235/80R17E10120/117R6.0 - 7.56.531.89.16551748.53085 / 283580-
28030718LT245/70R17E10119/116S6.5 - 8.0730.89.86761748.33000 / 275580-
28030711LT245/75R17E10121/118S6.5 - 7.5731.79.56571751.43195 / 291080-
28030332LT255/80R17E10121/118S6.5 - 8.5733.1106321752.53195 / 291080-
28030712LT265/70R17E10121/118S7.0 - 8.5831.910.76531752.93195 / 291080-
28030907LT275/70R17C6114/110S7.0 - 8.5832.411.16441857.12600 / 233550-
59000350LT285/70R17C6116/113Q7.5 - 9.08.532.811.16341860.62755 / 253550
AZ_Liberty
2007 Expedition
I detest P rated tires. They puncture super easily.
C rating is a nice compromise between a P rating and an E rating, but they are awful hard to find.
As soon as the P rated minivan tires Ford shipped my Bronco with wear down a bit, I'll be buying something with a C rating.
Seems odd that the Cs are on the front though, I'd fully expect a dealer to put on the cheapest tire he could find, which would be the Ps.
Rocki
Rocki
I have a suspicion that the original dealer put on a wheel, tire and running board kit which would make sense on the cheaper p rated tires
