MIC Hardtop Torque Specs
rzarezai
Rezai
Chicago, IL
23 EG Badlands Sas, 7MT
So I took my top off for the 4th and it was a blast. Plan to do it more often, but the time has come to put the top back on. Does anyone know the torque specs of the 10 TP50 bronco bolts that screw in to secure the top?
Thanks
Ducati1098
  1. Remove the hard top rear cap mounting bolts on C-piller.
    Torque: 106 lb.in (12 Nm)
  1. NOTE: LH side shown, RH similar.
    Remove the 4 bolts from each side.
rzarezai
Rezai
Chicago, IL
That is way lower than I expected. So only 9 ft Lbs?
ChrisB351
Shreveport, LA
Ive never even considered torque specs and just run em down tight with my cordless driver then 1/4 turn
JonDW29
Jon
NoVA
'16 F-150
I use the Rockworkx thumb screws and just screw them in until their hand snug. Even doing that sometimes I need to use a small screwdriver to get them started loosening up some. Never seen an issue.
X JBM X
boston
wildtrak
cordless impact drill does the trick... i don't think they need to be super snug... but you don't want the top to come off either.
tock13
Tony
WA State
Mazda, 66 Honda CT90, ‘94 Toyota Xtra cab
Weird soft top side trim piece? Don't think I removed it for the hardtop install and I wonder why it needs to be removed?
I’m wondering the same thing. The soft price doesn’t seem to be built in a way it even comes close to touching the hard top. I’d like to just leave the soft top piece in all the time.
Lak34ers
Troy
Seattle
All the videos I watched never mention the softtop piece. Must be fine to leave in.
Combustion_King
Derek
MA
Yes
I use my cordless ratchet to get them all in, then take the hand tool ratchet provided and final snug all of them
