Installing tow hitch. Rear bumper torque specs?
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Insallling tow hitch: is thier torque specs for rear bumper? Please and thank you
FYI: I got to the last bolt the one for the wire harness bracket with the clip - and even set at 20 lb - it snapped as it clicked. So, I would go lower. 15-18?
Boxer4
TRUCK
You don’t need to with the Curt hitch…110 ft-lbs. ~$120 from Realtruck.com
Thanks for the info ! -Just ordered it at $ 121 total cost. Thinking the " Ford brand" is set up for a factory install on the assembly line and maybe that is why the nuts are welded were they are.
WheelMe
Patrick
Northern California
2022 Bronco Badlands Sasquatch 2.7L
Just installed this - it's sturdy. Removal was fairly easy, but installation took two people holding each end, while a third person lines up the holes to insert the bolts. Not bad overall, and great factory fit and look.
Now on to figuring out how to connect the trailer tow harness to the tail lights.
Ford Bronco Installing tow hitch.  Rear bumper torque specs? PXL_20220709_193232656
Ford Bronco Installing tow hitch.  Rear bumper torque specs? PXL_20220709_220621324
Ford Bronco Installing tow hitch.  Rear bumper torque specs? PXL_20220709_220613887
Ford Bronco Installing tow hitch.  Rear bumper torque specs? PXL_20220709_193253507
