MIC cracking noise!!
umpire19
Ron
Pittsburgh
Ford escape
Probably beating a dead horse here but here I go. My MIC top (drivers side) kept making a poping & cracking sound every time I hit the slightest little bump. My solution white lithium grease. Been 3 weeks not a sound out of the MIC top. Keeping my fingers crossed 🤞. Took about 3 minutes of my time, top off spray pins put top back on. No big deal if I have to do it once a month or so. Just thought I'd throw that out there for anyone having same issue as I did.
shoelessjoe
2013 Chevy Cruze
Try heat shrink tubing on the pins.
Techun
Pa
BD, 2.7, MIC, 4dr
One wrap of electrical vinyl tape worked for me
Hurls
Avalanche
Heat shrink tubing is the cure. Fast and simple fix.
BlueOvalBandit
Kenneth
Anaheim, CA
Tacoma
Lube is even faster. A q-tip dab on all the locating pins last December and haven't heard a peep since. Don't even need to remove the panels, just unclip them, pop them up just enough for the locating pins to clear their hole, dab lube, and done.
I used super lube, cause I have it and it's clear.
