MFuse Help - Locating Multi Pack Replacement
Gtrekker
Gary
Hey,
Need some help finding a supplier for Mfuses.
I've order 2 packages from Amazon, neither fit. The same at the auto parts store.
Plan to hit Napa Monday.
Is there a part number or a better name / specific type? This came from the fuse box under the hood.
It shouldn't be this hard...🤔
Ford Bronco MFuse Help - Locating Multi Pack Replacement 17451747495217934634406551833576
Gtrekker
Gtrekker
Gary
Not a multipack, but the correct part numbers for individual fuses.
You are the Best!!! Ur always here for us... Thank you !
If I find a multi variety pack, I'll add it to this post.
n5mj
Carlsbad, NM
'22, '93 Bronco '97 Ranger '03 Sport Trac '11 SHO
Gtrekker
Gtrekker
Gary
CalvinT
Calvin
Phoenix, AZ
n5mj
Carlsbad, NM
Hey, thanks! Did they fit the Bronco? I have a kit arriving Tuesday using PN's.
I'll compare them with ur kits dimensions and post it.
Fit just fine in the half-size holes. I took one out to check. I don't understand why there has to be so many different sizes (3?4?) in a Ford nowadays. Good luck!
Gtrekker
Gtrekker
Gary
Hey,
Update to original post...
The kit i ordered fit n compared to the ones that were recommended so all do work n just a matter of preference.
https://a.co/d/4QAuV1C
These are the ones that came in, 3rd attempt from Amazon.
I also layed the others inside the fuse box as spares, nice fit.
There appear to be more 30amps used so a few extra would be good to have available.
Thanks all who responded n now we have a thread that can be searched found. 👍👍
