Method Center Cap Removal
bigbmc26
The Triangle, NC
2003 Lincoln LS V8 2016 Focus ST 2023 Bronco OB
Anyone had any luck removing the Method center caps without removing the wheel? I've got a set of Ford Performance ones to add, but the existing Method ones don't leave much room for a removal tool.
Ford Bronco Method Center Cap Removal 20240528_120828
Ford Bronco Method Center Cap Removal 20240528_120847
ksarantakos
Kyri
New York, NY
2022 Expedition Timerberline, 2024 Bronco OBX 2.7L
I also got the new performance caps. What I did after struggling and not wanting to remove all 4 wheels is I got a 3/8 inch bit and drilled slowly in and pull them out with the drill bit stuck in the cap. This obviously not a good option if you want to keep the caps.
bigbmc26
bigbmc26
The Triangle, NC
Lol, thanks, but I do want to keep the Method caps incase i sell the wheels in the future. I also don't want to pull each wheel off to update them. I just don't have the time.
DirectHit
Brandon
Tennessee
23 Gladiator, 23 Badlands 4dr, 23 Wildtrak 2dr
I’ve removed mine with a small pick. Also where can I buy the ford ones?
bigbmc26
bigbmc26
The Triangle, NC
WheresMyBronco
Los Angeles
2023 Badlands
Maybe melt a hot glue gun stick onto the center cap and try pulling it after? Kind of like those glue gun dent pulling kits
Demon4x4
Randall
Space City
demon4x4.com
2024 Bronco
Is taking the wheel off that hard? Probably takes less time than posting this thread.
bigbmc26
bigbmc26
The Triangle, NC
Not when you have a toddler running around 😉. I have my daughter daily.
Aonarch
Jack Hoff
MT
Just take the wheel off. Not worth damaging your wheels with a pick.
Ft. Worth Rob
Ft. Worth
BMW X7, Bronco OBX
I’m guessing you take your Bronco to have the tires rotated. Just have them swap them the next time you take it.
DriveAllNight
Dan
N.J.
24 Wildtrak, 25 Audi Q6 etron Quattro
I'm surprised they didn't make Bronco center caps for the Method rims
Bigmoose
Jon
RI
2019 Flex Ecoboost Limited
There is not good way without risking damaging the existing cap without removing the wheels.
What is crazy is Ford Accessories now sells the method wheels with the new center caps for the same price.
