Maxtrax mounting options with a soft top Bronco
Bird Dog Off Road
Bird Dog Off Road
Jody
Phoenix, AZ
www.youtube.com
I have been pretty happy with this setup, as it mounts the boards solidly to the tire with easy access if needed. The roof wasn't an option, both kids, and myself, prefer to explore the state forest by us with the roof of.
This is how I mounted them. I didn't want them horizontally across the top of the tire, although that would have been even easier. I drilled new mounting holes to lift the boards and give clearance to the bumper. The plate was designed around Maxtrax boards so the pins bolted right on. I have been out in the woods and mud holes a few times, they haven't move moved and they don't rattle at all.
Wonder if there is a way to mount this to the RC Tailgate reinforcement plate...
Stick355
2004 Mach 1, 2020 Explorer ST, 2021 Ranger Tremor
I appreciate the insight. I guess just threading some small rachet straps through wheel and board is less then ideal solution. Ha.
No worries. I honestly would have went that route if not for the access to the rear tire. Getting a hand me down Rock Slide setup also helped. This wouldn't be the most economical solution had I had to purchase everything. But for the limited use, day trips, this works really well for me.
Sorry, that I can't answer.
Bird Dog Off Road
Bird Dog Off Road
Jody
Phoenix, AZ
www.youtube.com
ICUGAZN
Kevin
Woodbridge, Virginia
2019 Raptor
Some more info: The BadAss tents spare tire mount fits some other brand of recovery boards, not MaxTrax using MaxTrax pins, so that may not be a good investment. Regardless of that, the MaxTrack really struggle to clear the rear bumper on the stock spare tire placement. As of now I'm probably going to bite the bullet and go american adventure lab STP. Had I done that from the beginning I'd probably have it already and be ready to roll.
Did you get the Adventure Labs STP?
projectrally
Adam
South Portland, ME
2019 MX-5 RF / Factory Five 818 / 2018 CX-5 GT
I was, unfortunately I don't have any other pics with me. I will try and get a better detailed set of pics and info this evening.
So to confirm the setup, you've got the Rockslide Engineering EZ Rack strapped to the tire, and then on one of those plates you've got the RacksBrax MaxTrax carrier, which you custom mounted by drilling some new holes into the RacksBrax. Is that right?
DoYouBronco
Lux Sponsor (Level 2)
Tyson
El Paso
hpbuilt.shop
Testing out our maxtrax molle mount as we speak!
We believe in displacing as much weight away from the oem tire carrier as possible to minimize stress to the tailgate sheet metal. We incorporated an accessory arm to our support kit to mount a rotopax/antenna and now the traction board system w/ 1 gallon tank!
testing out afew different ways to stabilize the boards, after sufficient desert testing and a few revisions we will be releasing all the details!
Bird Dog Off Road
Bird Dog Off Road
Jody
Phoenix, AZ
www.youtube.com
Can’t wait to get them!
LC4Dakar
Art
New Mexico
Lotus 7, Land Rover Series 2a
The OBX stock wheels have spokes in good places to mount the ROK Straps so the Maxtrax's are off to one side. Attached just like the Jeep video but located off to the side so the camera still works. You only see a small part in the camera. You have to mount it as high as possible or the backup sensor beeps every time you put it into reverse.
Ford Bronco Maxtrax mounting options with a soft top Bronco IMG_20220802_094322243_HDR[1]
Ford Bronco Maxtrax mounting options with a soft top Bronco IMG_20220802_094355858[1]
Ford Bronco Maxtrax mounting options with a soft top Bronco IMG_20220802_094055265[1]
AK SNO RIDER
Ty
Alaska
And here I am thinking there was plenty of room 🤷‍♂️
Were you thinking horizontally against the wheel face, above the camera? This is what I'm envisioning, just waiting to see someone else do it and if it fits.
It's not the easiest on and off and we'll see how well they stay put on rough roads but imma find out.
Ford Bronco Maxtrax mounting options with a soft top Bronco 20220802_085949
Bird Dog Off Road
Bird Dog Off Road
Jody
Phoenix, AZ
www.youtube.com
I added the Hammer Bilt reinforcement kit with the Maxtrax plate ordered (still in R&D. While waiting for the Hammer bilt plate I was able to mount the RacksBrax plate for now.
Ford Bronco Maxtrax mounting options with a soft top Bronco E730C21E-83CC-4AA1-BF5B-C8BBC5C43662
Ford Bronco Maxtrax mounting options with a soft top Bronco 84ABE4AD-A728-4BF8-9B4D-4E9B1BEFC246
Ford Bronco Maxtrax mounting options with a soft top Bronco 3D87AD7B-B510-433D-B6EE-3F9FB32C6E78
Ford Bronco Maxtrax mounting options with a soft top Bronco F8D3771D-605A-4EF6-8213-389802675710
Ford Bronco Maxtrax mounting options with a soft top Bronco 6BDB71DA-30BE-411C-8290-6B5833B91A02
Ford Bronco Maxtrax mounting options with a soft top Bronco B8A0EBCA-76AE-4163-B812-86856D8ACD32
lmarchetti
Luke
Ill post a option that's a little different. Mini's. In the winter the stay strapped to the back of the rear seats. They can link together if you like or put them under all 4 tires.
Ford Bronco Maxtrax mounting options with a soft top Bronco 20220117_150442
Ford Bronco Maxtrax mounting options with a soft top Bronco 20220504_131452
LC4Dakar
Art
New Mexico
4,400 miles on the CDT and the freeway home and no problems with ROK Straps.
Ford Bronco Maxtrax mounting options with a soft top Bronco 1662161433892
nd2002
Seattle
'17 BMW M2, '18 Audi Q7
Also fits snug, right between the back seats and the wheel wells
Ford Bronco Maxtrax mounting options with a soft top Bronco C3BC7653-CB24-4DCF-B353-EF5E948732E5
