Manual Transmission Noise Poll
Do you hear this noise?
  • Total voters
    474
Gnomad
Harbor Springs
Land Rover LR3 HSE
I should maybe have the dealer look at it. verify it and then when it gets warm enough to ride the motorcycle to work I can let them do the job. If the parts are available that is.
Hot cheetos
Illinois
2008 Ford Ranger/2004 Pontiac GTO
Dang. Disappointing you are having the sound already. Do you have an idea how the volume/type of sound on your brand new vehicle, compares to some other vehicles around here with many more miles?
I do not, I have yet to meet up with any of the locals and the few random ones I've run into at the gas station or whatever were autos or I didn't know this was an issue and didn't listen.
This also shows Ford has done nothing to fix the issue with current builds, mine is a 2/3/23 blend date. So Ford is apparently going to continue shoving these out the door and not have any real solution when they put thousand and thousands more out there before fixing it.
Either way it was manual for me no matter what, ideally ford makes this right at some point, but if I had to replace the trans myself and there was a solid aftermarket option after, I'd still rather do that then have gotten the 10 speed auto.
rzshootr
Walter
Los Angeles
Audi A3 Etron
Yup, just got my 2Dr Manual Badlands last Friday. Less than 200 miles on it and it definitely makes that weird scrapping type noise. Mostly I hear it in first and second gear. That sound definitely does not inspire confidence. Brand new! And I just spent a small fortune after a two year wait!
@Ford
what am I supposed to do about this!?
gtabert
Greg
Woodstock, IL
'18 gt350r / '65 f100 / '99 Silverado / '15 VW TDI
Well, that didn't take long. Under 60 miles on it and started it this morning and heard it.
That's a bummer, sorry to hear you have this. I picked mine up on Saturday, so far 200+ miles and, dare I say, no noise. I do have a lot of wind noise, when on a phone call everyone comments on that awful wind noise.
@Ford
Sorry to hear you are having this problem, I picked up my Badlands Sasquatch 2 Door Saturday. I have 200 miles as of now and nothing. I do have a lot of wind noise, when on the cell phone all have commented on what is that AWFUL wind noise, I hope that is my only complaint on noise I'll have to deal with. No matter, we all all in this together, I would be interested in knowing out of all the Manuals delivered so far, how many have issues. Not just from this site but the thousands who have the MT and are not part of any Forum.
Hot cheetos
Illinois
I don't think the wind noise is that bad? Do you have the sound deadener in yours? I haven't taken it on the highway yet, but have gone over 60 mph and thought it was more than acceptable
Tricky Dick
Dick
PNW
www.TD-Distributing.com
Some hard top front panels have big gaps in the weatherstripping and cause a lot of noise.
gtabert
Greg
Woodstock, IL
I do have the sound deadener, my wife even commented on the wind noise. My son suggested I take off the top to be sure it is seated properly. I plan on doing that and applying some Gummie-Pflege to the seals - https://www.getbmwparts.com/oem-parts/bmw-bmw-gummi-pflege-rubber-care-83192449390 - this product is a BWM lubricant I used many times on my M3 sunroof, door and window seals, its an amazing product, keeping the seals soft and pliable with an annual application and helps in the winter with the freeze conditions. Its has the consistency of vaseline, but leaves no residue on the surfaces after application. Figure its worth a try.
BigHoof
PA
Ram 2500
How did you get your Bronco so fast? Dealer next to the plant?
cpmartin1999
chris
Atlanta
2022 Badlands, 2020 VW Atlas
It causes some extent of permanent damage. 5&6 synchro gears rub their side faces causing friction weld marks and scrapes. That's about the extent that's been discovered though. Not enough damaged to make it blown apart or anything, so no addiitonal damage has been reported as a result. Some of us have 10k+ with the noise being there and no changes from it first appearing and no performance issues, just an annoying scrap sound.
i have this also, AND its my second badlands, put 15K miles on first one and have 12K on this one, both made that noise always goes away when warm, i noticed it from the start and didnt think anything about it, today is the first day i totally tested it by moving shifter towards 6th and yep same as yall been reporting!!
I3lackRose
Justin
Ohio
More and more I honestly think it's all of them with varying severity. Bad design.
Tricky Dick
Dick
PNW
My hunch as well. The 26% saying no just have it too quiet to hear yet.
I3lackRose
Justin
Ohio
That would be a bummer. :( During my short time test driving a Bronco, I liked the feel and performance of the manual. Plus Ford even came through with the crawler gear. Hope it all works out.
I mean this is a thing with 21s, 22s and fresh 23s on delivery day. I think we just have varying levels of severity some so faint they don't question it so it's not being reported while others like mine you can hear coming down the road. Countless people are finding these threads like didn't know I had an issue till I found this thread.... It's depressing! $50k and sounds like I have a can of rocks under my car. This is what I waited almost 3 years for?
